Old Jun 18, 2013, 09:03 PM
extragreaseplz is offline
Find More Posts by extragreaseplz
ten ton hammer
extragreaseplz's Avatar
Joined May 2013
In too deep
Hello everyone I'm new to the website and rc boat hobby. I have a aquacraft nitro hammer that's stripped down too the bare bones and ready for paint.
So here is my question I've bought paint at the lhs but how should start sand, primer then paint. For sanding I have red scotch bright pad and 400, 600, 1000 grit paper. I also have pure denature alcohol should I use this stuff after sanding to clean the surface with or will soap water work.
extragreaseplz is offline Find More Posts by extragreaseplz
Old Jun 18, 2013, 10:56 PM
Ron Olson is offline
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
The Tamiya paint isn't fuelproof, unfortunately I know as a guy at a LHS told me it was so I was dumb enough to listen to him.
Top-Flite's Lustrekote works much better and will handle more nitro than what they say on the can. They don't have the big variety of colors they used to have but it won't run down the sides of your hull if nitro hits it. If you get some, use the white as a primer, not their primer white as it's tough to sand and the regular white covers your gel-coat better.
Ron Olson is offline Find More Posts by Ron Olson
Old Jun 20, 2013, 12:21 PM
ten ton hammer
Joined May 2013
Okay I will order some of top paint tonight they have a clear coat too. Also when I sand it should I start with the 400 grit or red scotch bright pad.
Old Jun 20, 2013, 12:45 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
You shouldn't need much in the way of prep work, mostly just wiping it down with a solvent or dish-washing soap to remove any oils or fuel. You can lightly sand it if you wish for better paint adhesion.
Discussion Kyosho Blizzard SR playing in deep snow Fast Guy RC Tanks 3 Apr 21, 2013 05:00 PM
Question made too deep a cut on an epp fuse grfcon Dynamic Soaring 20 Apr 27, 2010 12:54 PM
Discussion in too deep? bri_877 Electric Ducted Fan Jet Talk 4 Jan 02, 2007 11:08 AM
Discussion 2nd day checking out the hobby.....IN TOO DEEP! customminatures Scratchbuilt Indoor and Micro Models 13 Apr 29, 2006 08:19 PM
Simprop discharges too deep on AUTO Al P Power Systems 1 Jan 19, 2002 11:36 AM
