Old Jan 15, 2013, 05:20 AM
rccsofla is offline
Find More Posts by rccsofla
Joined Dec 2011
Fuel plane battery pack
How do you know when to recharge the battery pack for the servos,etc?I it's not a lipo so i assume it has a memory?
rccsofla is offline Find More Posts by rccsofla
Old Jan 15, 2013, 06:37 AM
AA5BY is online now
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
If the pack is NiCad or NiMh then the remaining capacity is determined somewhat by a voltage check while applying a load. A load meter will be needed.
If a 4 cell 4.8 volt it can be flown down to 4.6 v whereas a 5 cell 6v pack down to 5.75v.
It requires applying some thought as one would not start a flight at 4.7 volts with a 400mah battery whereas with an 1100 doing so might be reasonable.
It is prudent to take a load reading before every flight. Doing so has saved many a plane.
AA5BY is online now Find More Posts by AA5BY
Old Jan 15, 2013, 06:50 AM
jetmech05 is online now
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Charge every morning before you fly at first monitor your voltage with a loaded voltmeter after every flight to get an idea of what you use a flight. Then you can monitor your voltage after say the third flight. Don't ever go below 1.1 v a cell
jetmech05 is online now Find More Posts by jetmech05
Old Jan 15, 2013, 07:35 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I usually charge the night before or the morning before flying. Normally at about 400 to 500ma charge rate. When recharging at the field, I'll go as high as 1 amp. In addition to what the others said, I use my ESV (Expanded Scale Voltmeter) to test my batteries before, then after each flight. Over 20 years I've lost 3 planes to battery failure. Believe me, you feel really stupid when that happens.
I cycle test all my flight batteries every spring, except lipo's. I usually find at least one that is less than 80%. That's when I take them out of service and turn it into a bench battery. Others go down to 70% but thats just a personal choice. Its important to setup a procedure and be consistant. Batteries fail, you dont want to loose a plane if you can help it.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jan 15, 2013, 08:15 AM
rccsofla is offline
Joined Dec 2011
Thanks for the replies.As you can see I'm new to glow engines.Been flying battery up til now.Like the idea of a real engine with the noise and smoke.They are fun!
Old Jan 15, 2013, 08:48 AM
AA5BY is online now
AA5BY's Avatar
East Texas
Joined Aug 2007
We all had our day as a beginner. Don't hesitate to ask, if needing info.
Best of luck and enjoyment.
Old Jan 15, 2013, 09:04 AM
scootrb4 is online now
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
I'm new too and I already had a battery failure. Luckily I saved the plane. I found a small on board voltmeter read out, led type. I mounted it in the dash and it comes on with the power switch so I can know at a glance what the charge is.
scootrb4 is online now Find More Posts by scootrb4
Old Jan 15, 2013, 09:13 AM
LesUyeda is online now
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I use a thing called "Voltwatch". A series of led's that go from green (good) to red (bad). I turn things on, run the sticks around, so that several channels are excersized simultaneously, and if any drop into the red, I know the pack is too low.
Les
LesUyeda is online now Find More Posts by LesUyeda
Old Jan 15, 2013, 09:22 AM
AA5BY is online now
AA5BY's Avatar
East Texas
Joined Aug 2007
Glad the plane wasn't lost. Any help one can get to monitor a battery is a good thing and it sounds like the device described will work well.
Newer radios often have telemetry, which is the cats meow offering real time condition and sounding a warning if either Tx or Rx batteries fall below a set voltage level.
There is also newer battery technology and some as myself are converting to LiFe though I think the biggest plus for it is for those who have a large hanger as NiCad and NiMh don't seem to like inactivity.
Old Jan 15, 2013, 01:13 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
If your using a DX8 you could use a TM1000 telematry module. I have mine connected to the RX voltage and the pack voltage with an alarm if it gets to low.
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Old Jan 15, 2013, 02:08 PM
scottieusa is offline
Find More Posts by scottieusa
scottieusa's Avatar
United States, OR, Albany
Joined Oct 2011
I just converted one of my electrics to a 4 stroke nitro and I love it. Its also my first fuel set up after flying only electrics for a couple of years. Such a great sound, I see many more in my future.
scottieusa is offline Find More Posts by scottieusa
Old Jan 17, 2013, 07:39 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
NiCD are banned in various parts of the world incl EU ... so most now use NiMH ....
NiMH can be charged at any state with the standard charger ... or via a Delta Peak detection charger ......... without the problems we used to have with NiCD's where cycling was a duty done regularly.
I charge up my NiMH night before flying - that's the RX and Ignition packs both. Regardless of how much used out of them prior session ... and they are still top-notch a year later ...
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 18, 2013, 05:12 PM
ryanbe15 is offline
Find More Posts by ryanbe15
ryanbe15's Avatar
United States, MD, Bethesda
Joined Sep 2012
can you provide a link to that meter that provides load?
ryanbe15 is offline Find More Posts by ryanbe15
Old Jan 18, 2013, 05:54 PM
AA5BY is online now
AA5BY's Avatar
East Texas
Joined Aug 2007
There are numerous to choose from. I'll link to the one I use.
http://www.experiencerc.com/store/rc...ge-p-7509.html
Old Jan 18, 2013, 07:50 PM
Joined Sep 2003
I use an older Tower ESV, it switches between 4.8v and 6v on the receiver.
http://www.horizonhobby.com/webapp/w...pe=productgrid
http://www3.towerhobbies.com/cgi-bin...?&I=LXWDZ5&P=7
Edwin
Discussion Fuel's affect on plane's CG; where will the fuel predominantly reside? Ian Davidson Fuel Plane Talk 35 Nov 28, 2014 04:41 AM
Sold Two New Dewalt DC9360 Battery Pack In Blister Packs Rickochet Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 07, 2012 08:37 AM
For Sale Four SR "MAX" Battery Packs 2 NEW Packs ALL American Boats (FS/W) 1 Apr 16, 2012 03:07 PM
Discussion Where can I buy square pack NiMh battery packs? Riodiler1 Batteries and Chargers 7 Mar 14, 2012 09:46 AM
FS: TX battery pack and fuel pump petn7 Aircraft - Fuel - Airplanes (FS/W) 0 May 18, 2004 10:43 PM
