Old Jan 10, 2013, 07:11 PM
Hornetnz is offline
Find More Posts by Hornetnz
Grand Rapids, MI
Joined Jun 2005
Question
HK Light Strip Wiring 101
Do the strips have to be wired from the end of one to the other? Or can I run wires from the power connection to each strip individually?
Hornetnz is offline Find More Posts by Hornetnz
Old Jan 10, 2013, 10:04 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Assuming you're talking about these: http://www.hobbyking.com/hobbyking/s...lue_1mtr_.html (or one of the color variants)
You can do it either way, but wiring them individual usually requires more wire... Remember that the smallest you can cut them is 3 leds and you must cut on the indicated cut lines.
-K
How's the flying weather in GR? I'm from Marquette originally.
kad is offline Find More Posts by kad
Old Jan 11, 2013, 07:26 AM
Hornetnz is offline
Grand Rapids, MI
Joined Jun 2005
Thanks. I assumed it wouldn't make a difference, but thought it better to ask first. The reason being, end to end wiring in this plane with where I'm putting the strips will be a pain.
Weather has been decent. Little to no snow right now, so no skis required. Bit windy lately, but we flew on Jan 1st again this year and had a good turnout with winds ~5mph, partly sunny and not overly cold.
Old Jan 12, 2013, 08:44 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
also you can soldier onto a strip and take off in another direction anywhere along the run. very convenient.
goodhumormarc is offline Find More Posts by goodhumormarc
Discussion Hobbyking led light strips in series? Score0985 Night Flying 9 Mar 13, 2014 12:03 PM
Discussion HK light strips, 4s ? Ronnie2 Night Flying 11 Jan 01, 2013 04:32 PM
Found Turnigy high density r/c led flexible light strip - white gromitvt10 Aircraft - General - Miscellaneous (FS/W) 0 Mar 05, 2012 10:53 AM
Discussion Other sources for HK style light strips? CyberJay Night Flying 7 Nov 16, 2010 03:51 AM
Mini-HowTo Need some help with HK light strip nakelp86 Night Flying 28 Sep 29, 2010 10:25 AM
