Old Mar 23, 2012, 11:20 AM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
How to do a t-tail?
Does anyone have a link to a thread that shows how to set up the linkages for a T-tail type vertical stab?Or just any suggestions on how to do it at all, would be much appreciated!
Jake
TheTrashMan is offline Find More Posts by TheTrashMan
Old Mar 23, 2012, 12:49 PM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
Not a foamie, but on a balsa plane I built awhile ago I made the vertical stab from three layers of balsa with a cable linkage running up through the inside. Works great.
Alternatively, you could mount the elevator servo in the vertical stab and do a direct pushrod linkage.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Mar 23, 2012, 01:05 PM
SNice is online now
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Elevator in stab is a good one - simplest and most efficient (for the servo) but you must be sure that the model will still balance properlt with servo weight so far back in the tail.
I recently built an Icon A5 - it has a T-tail - I used flexible pushrod systems to get the elevator to work. With the flexrods, you have to be careful not to bend too sharply as it will put a lot of strain on the servo and will slow down your surface movement.
link here:
http://www.rcgroups.com/forums/showthread.php?t=1606211
Here's another one with a more mechanical solution - it looks like it works great, but there are a lot of parts and everything is external...
link here:
http://www.rcgroups.com/forums/showthread.php?t=1428321
good luck & happy flying!
SNice is online now Find More Posts by SNice
Help! how to how do you build the tail pitch slider for walkera m120d01 flohio117 Micro Helis 11 Jan 05, 2012 10:59 AM
How do you get faster tail response for T-rex? Mmarshall Mini Helis 30 Jul 29, 2006 10:39 PM
Idea T-tail how do I build the best one? John K Electric Sailplanes 0 Dec 11, 2001 06:14 AM
