Old Feb 03, 2012, 08:31 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Air-C-Race Nemesis NXT
Father Christmas came a little late this year,but it was worth the wait
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Feb 03, 2012, 08:56 PM
ViperZ is offline
Find More Posts by ViperZ
This is my Nemesis....
ViperZ's Avatar
Canada, SK, Saskatoon
Joined Jan 2011
Tease!!!
ViperZ is offline Find More Posts by ViperZ
Old Feb 04, 2012, 10:23 AM
Vantagepoint is offline
Find More Posts by Vantagepoint
United States, TN, Nashville
Joined Aug 2008
Adrian,
What's in the big box?
Vantagepoint is offline Find More Posts by Vantagepoint
Old Feb 04, 2012, 03:59 PM
Adrian_M is offline
Joined Dec 2010
I finally got to unpack the box this morning, it was well packaged in a thick box,It is a very nice Kit indeed compared to what you got in the original one.
This plane is the revised version the whole fuse is now molded in two half and joined together,with plenty carbon on the side of the fuse for stiffness.servo tray,battery tray,wing bolts etc,and everything else is done,you get a carbon fiber spinner with aluminum backing plate the hatch is pre fitted,it's 70% built all you have to do is glue the horizontal stab, fit the servos & linkages make motor mount,fit motor,esc I also like the position of the wing servos so the aileron horn is positioned in the middle of the aileron, the servo covers where missing but they are on their way
I'm going to use Eflight electric 90-120 retract units and fit the legs on them, i tried one from a friends kit they will fit with minor work
There is plenty of room for lipos in there 10s 12s setups if you wanted to
I have two setups in mind for this plane, to maiden i will run High kv outrunner on 6s 10x10 or 11x10 prop and later HyperionHS-4035-500kv on 10/12s should be able to squeeze 4000watts in short bursts from the setup see how fast this baby can go
The NXT is a HotRod, beautiful plane I hope it will fly as good as it looks
here are a few pics i will post more when i start the build
This is where i purchased the plane from, in NZ Jim is a great guy to deal with
http://www.radiocontrols.co.nz/
Old Feb 04, 2012, 11:24 PM
ViperZ is offline
ViperZ's Avatar
Joined Jan 2011
Very nice!
Whoever said this is not a high performance needs to put away the modeling dope
Old Feb 05, 2012, 01:01 AM
jetdryvr is offline
Find More Posts by jetdryvr
jetdryvr's Avatar
United States, CA, Fairfield
Joined Aug 2004
I'm jealous Adrian. That proposed setup sounds perfect! That's about what I would put in so I look forward to your maiden report. By the way....you look sick...I think you need to call your employer and tell him you're not feeling well until your plane gets done.
Erik
jetdryvr is offline Find More Posts by jetdryvr
Old Feb 05, 2012, 01:09 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Im going to have to report you to a moderator.... there are rules about posting these kind of sexy pictures on this website....
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Feb 05, 2012, 02:42 PM
Adrian_M is offline
Joined Dec 2010
Erik
Hi Erik I know that you looked at this plane in the other forum like i did I'm glad that i held back till now,this new version of the plane is so much better the fuse much stiffer, two piece now to 3 piece before then you had to glue the nose in etc.
yes i like this version much better and really it's as close as you will get to any Arf kit
The fuse is really wide 150mm at it's narrowest part,with the 10s lipos from my SD50 makes them look really small
For the HV setup i will now go with 12s 2x Nanotech 5000mAh 6s 35-70c they will be good for 175 amps continuous,and the 6s setup i will use my 2 1/2+ year old Hyperion G3 2 x 5500mAh 35-65c 3s in series they still have plenty of juice in them and balance up a treat
Old Feb 05, 2012, 02:50 PM
MarcusT is offline
Find More Posts by MarcusT
Mark Triebes
MarcusT's Avatar
Elk Grove, CA
Joined Sep 2001
Do it, Erik ... you know you want to!
MarcusT is offline Find More Posts by MarcusT
Old Feb 05, 2012, 06:55 PM
Adrian_M is offline
Joined Dec 2010
There s plenty of room on the bottom tray for Esc's, Atlas 180Amp 26V and 130Amp 50V HV 6 & 12s setups.
I'm going to water cut a new battery tray from 2 mm carbon plate to accomodate my batterys configuration,the original tray is fine for a 6s setup using lipos around 137mm long x 53mm wide,my lipos will run longways on the new tray
The best thing about this plane is the amount of working room you have in the plane with the hatch off you have an openig of 500mm long x 150mm wide
Old Feb 06, 2012, 07:44 PM
jetdryvr is offline
jetdryvr's Avatar
Joined Aug 2004
Thanks for the extra info Adrian.
I knew that fuselage was fat from the pictures but wow!
Should be a really easy install once the cg is right.
Glad to hear the plane has been improved. I didn't know they changed it.
Mark.....you're right I'm trying hard not to do it.
Erik
Oh yea, Adrian can you snap a photo of the airfoil for us?
Thanks!
Old Feb 07, 2012, 03:56 AM
Adrian_M is offline
Joined Dec 2010
Erik
Thanks!
Hi Erik
I will take a few pictures of the wing tomorrow morning for you, anything else you need to know just ask
Cheers
Adrian
Old Feb 07, 2012, 01:49 PM
Adrian_M is offline
Joined Dec 2010
Some pics for Erik
Old Feb 07, 2012, 07:11 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
Very nice plane Adrian!
This is one of the few "BIG" planes that can fly with the speed of an F5D ship.
Grtz René
E-speed buff is offline Find More Posts by E-speed buff
Old Feb 07, 2012, 08:05 PM
jetdryvr is offline
jetdryvr's Avatar
Joined Aug 2004
Thanks again Adrian. It looks great. I'm going to go watch the youtube flights of this thing.
Erik
Discussion Hobby King Nemesis NXT ViperZ High Performance 147 Feb 27, 2015 06:38 PM
Kinda OT: Nemesis NXT JFisher304 High Performance 29 May 13, 2012 09:08 PM
Discussion Composite Nemesis NXT motor suggestions Ali High Performance 4 May 13, 2012 12:19 PM
Discussion Nemesis NXT scratch build 1/16th full fuse. Jwmflying14 Foamies (Scratchbuilt) 14 Sep 08, 2011 07:57 AM
Discussion Air-C-Race Pond Racer electrified sml Giant Electric Planes 4 May 27, 2011 08:05 AM
