Old Mar 30, 2015, 03:22 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Thanks for the link.
I'll see if my brother can either repair or fancies cutting some cores for me. The UK seller of the SP only lists fuses as spares
http://www.slopeside.co.uk/speedo-mk...ider-sailplane
Andy
headlessagain is offline Find More Posts by headlessagain
Old Apr 10, 2015, 04:54 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Got my Speedo wing mended. Removed the film underneath and my brother reckoned it looked like a scarf joint on the le top sheeting had separated, certainly a diagonal split. I flooded the joint with thin CA and stuffed the le cavity with EPP foam. All recovered but will need to balance the wings as one is heavier now
Andy
Old Apr 17, 2015, 02:23 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Took the SP for a spin today in gusts over 25 mph. No problems.
Speedo Pro 2 RC glider (3 min 53 sec)
Hope you enjoy the music
More impressive was the way that my 199g 26"/660mm w/span MPX Mini Solius coped with the conditions
Multiplex Mini Solius maiden flight in 25 mph wind (3 min 8 sec)
Andy
Help! instruction manual kiter32 Radios 1 May 14, 2011 07:00 PM
pz p51 instruction manual EDFPILOT Non R/C Items (FS/W) 2 Apr 04, 2011 01:44 PM
Wanted: Instruction Manual for SR Cutie Rudderman98 Aircraft - Electric - Airplanes (FS/W) 2 Jul 23, 2002 09:39 AM
needed: Instruction manual for FMS Supernova 250S Keitha Aircraft - Electric - Airplanes (FS/W) 3 Jun 18, 2002 07:11 PM
bandit instruction manual tqpham Electric Sailplanes 3 Mar 27, 2002 06:24 PM
