Old Mar 20, 2011, 05:34 PM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
USA, CA, Santa Clarita
Joined Feb 2008
Light and Simple Funjet for FPV
So now that I have my Twinstar setup exactly as I want it, Im thinking about a faster but lighter & more simple setup with a Funjet.
I'm thinkin' a 1800 or a 2200 3 cell, light cheap camera, light cheap tx & small, simple OSD just for voltage numbers.
I'd like to see what everyone else has in the way of a light & simple funjet.
Thanks in advance!
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Mar 20, 2011, 07:07 PM
Katabatic is offline
Find More Posts by Katabatic
AK
Joined Dec 2010
I wish these guys didn't more than double the price of the $9 OSD. Hopefully someone comes up with something similar for those of use that just want voltage numbers.
Katabatic is offline Find More Posts by Katabatic
Old Mar 24, 2011, 01:31 PM
Kyle D. is offline
Find More Posts by Kyle D.
Kyle D.'s Avatar
Troy, Michigan
Joined May 2006
I had the same idea. I wanted something to fly low and fast to weave in and out of things. I was thinking something like
Motor: http://www.hobbyking.com/hobbyking/s...idProduct=4197
ESC: http://www.hobbyking.com/hobbyking/s...dProduct=14872
Battery: 2200mah 3s
vTx: Lawmate 2.4 500mw
Camera: KX171 low voltage
Antennas: Clover leaf on the vTx and Skewer Planar Wheel on Rx
Tx: 72mhz
OSD: maybe have the once $9 osd, but i don't think it would be necessary.
I figured this would be a pretty good light setup and i would be able to have a solid video for about a mile in all directions and not have to worry about dropouts when flying around obsticles and banking hard thanks to IBCrazy's CP antennas.
Kyle D. is offline Find More Posts by Kyle D.
Old Mar 24, 2011, 01:38 PM
So Cal FPV Aviator
Joined Feb 2008
Now that's what I'm talking about.
Old Mar 24, 2011, 01:43 PM
iacei is online now
Find More Posts by iacei
Luxembourg
Joined May 2009
You missed the thread about the HK E-OSD it is the same for 12.5$
iacei is online now Find More Posts by iacei
Old Mar 24, 2011, 02:02 PM
Kyle D. is offline
Kyle D.'s Avatar
Troy, Michigan
Joined May 2006
I can't believe i didn't know about the hobbyking OSD!
Well all that added up comes out to be about $250. I might have to sell a few things and get one of these started.
So Cal FPV Aviator
Joined Feb 2008
a SIMPLE link works well...
http://hobbyking.com/hobbyking/store...dProduct=16662
Old Mar 24, 2011, 02:15 PM
So Cal FPV Aviator
Joined Feb 2008
Battery: 2200mah 3s
Tx: 72mhz
The motor you linked I think is a bit too heavy. A 60gram or lighter would be better. Even 5 gram servos for this application.
ESC looks good.
If we're talking light and cheap, here would be my list...
Funjet.
OSD http://hobbyking.com/hobbyking/store...dProduct=16662
Servos http://hobbyking.com/hobbyking/store...idProduct=8609
Flight pack http://hobbyking.com/hobbyking/store...dProduct=11905
Video Pack http://hobbyking.com/hobbyking/store...dProduct=16676
ESC: http://hobbyking.com/hobbyking/store...dProduct=15442
SunSky 1.2 VTX & Ib Crazy Super omni antennas
Old Mar 24, 2011, 03:30 PM
Blue Sky is offline
Find More Posts by Blue Sky
It just keeps getting better!
Blue Sky's Avatar
Eureka, CA
Joined Oct 2002
Not to reignite the 1 battery vs 2 battery argument but the main
reason I have for flying 2 batteries on my planes without an OSD is so I will still have video after the flight pack runs dry. I usually fly with a video battery that has about 2X the run time of the flight pack. I fly upwind with enough altitude that I can glide home. While I try not to fly to cutoff on the flight pack it does sometimes happen.
Blue Sky is offline Find More Posts by Blue Sky
Old Mar 24, 2011, 04:15 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Not simple and not the lightest, but this is THE setup for a funjet...
EZOSD
EZTracker
UHF system
This brings the FJ alive...
I loved making this video. It was first time with UHF and I wanted to see how far / high /fast I could go in 1 hour. It's capable of much more of course
http://www.vimeo.com/13828588
I'm running 2.4g on video
Single battery. I've been out past 2k on a few occasions with no motor. Plenty left for video.... FJ glides surprisingly well. I'm not against 2, but keep the FJ as light as you can.
Shikra is offline Find More Posts by Shikra
Old Mar 24, 2011, 05:23 PM
Kyle D. is offline
Kyle D.'s Avatar
Troy, Michigan
Joined May 2006
EyeFlyPlanes: What motor were you thinking? got any in mind?
Shikra: Awesome video! What was you power setup? Got any pictures? Ps. did you have your pan controlled by you rudder stick? I was thinking about maybe doing that
Old Mar 24, 2011, 05:41 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
ESC looks good.
Funjet.
With regard to the Esc, I've had two hk SS escs that worked fine, I've had maybe 5 that either smoked motors, themselves or nvr worked at all. Imo they should be avoided!
For a very cheap setup I'd go with
http://www.helidirect.com/hobbywing-...pto-p-4397.hdx
http://hobbyking.com/hobbyking/store...idProduct=6306
http://hobbyking.com/hobbyking/store...idProduct=7993
And a 6x4 apc prop.
NDw is offline Find More Posts by NDw
Old Mar 24, 2011, 08:11 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
That was a really nice video shikra... What the cam? -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old Mar 24, 2011, 10:18 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Amazing and relaxing video Shikra! Can you post the specs of your setup?
metalfred is offline Find More Posts by metalfred
Old Mar 24, 2011, 10:31 PM
MauiNate is offline
Find More Posts by MauiNate
United States, CA, Ventura
Joined Aug 2007
Why not a Stryker? Cheaper and a little more room inside I think...
MauiNate is offline Find More Posts by MauiNate
Discussion FPV and setup for Funjet femer Foamies (Kits) 4 Nov 22, 2010 01:45 AM
Sold Like New Light Fast Funjet RTF 4s w/ Little Screamers Super Parkjet motor beeker_12 Aircraft - Electric - Airplanes (FS/W) 2 Oct 27, 2010 10:36 AM
Sold Like New Light Fast Funjet RTF 4s w/ Little Screamers Super Parkjet motor beeker_12 Aircraft - Electric - Airplanes (FS/W) 2 Oct 16, 2010 02:52 AM
Help! Funjet for FPV?? G-unit FPV Talk 29 Sep 09, 2009 09:58 PM
Discussion Funjet FPV For SALE! Impulze FPV Talk 9 Sep 11, 2008 02:30 PM
