Old May 23, 2011, 07:57 AM
datyip is offline
Find More Posts by datyip
Spain
Joined May 2011
Originally Posted by IBCrazy View Post
You meant the patch? yes. The Skew-wheel and cloverleaf? If it's 1.1mm wire, yes. I never thought about it, but bailing wire would probably work fine for this antenna too.
-Alex
Sorry for not being clear.
I'm referring to the wire for building the spw/cloverleaf..
datyip is offline Find More Posts by datyip
Old May 23, 2011, 09:02 AM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Hey is there anyway to go CP with UHF 433mhz Rx/Tx's. I imagine the Rx antennas would be to large, but is there a way around that?
I've been getting bad multipathing on the Tx/Rx flying in the city but don't know of a better solution. The signal will just drop out completely in a matter of 2-3 seconds! It can't be a null because the Tx is an omni whip and I'm no where near the top end null (out 4000 feet and maybe 600ft up) and I'm not far enough out to be losing the signal (4000 ft LOS using a Scherrer LR UHF on the 2w setting). The Rx antennas are positioned in an "L" shape on either side of the Skywalker nose). And I don't think this is from RF because it's happened in two totally separate locations in the city.
AdamChicago is offline Find More Posts by AdamChicago
Old May 23, 2011, 09:42 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes: turnstile antenna. It is circularly polarized.
IBCrazy is offline Find More Posts by IBCrazy
Old May 23, 2011, 09:45 AM
Chicago, IL USA
Joined May 2010
Oh I didn't realize it was a CP. What would be a good Tx CP mate for it? I imagine the stock omni whip (even when tilted on its side) wouldn't be as good as a CP antenna?
Old May 23, 2011, 09:52 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'm not sure if I'd use it as a TX antenna or an RX antenna. An RX antenna might be easier to mount. Eiher way, it should help with some of your problems. multipathing shouldn't be too bad for a control system unless you are flying very low to the ground.
-Alex
Old May 23, 2011, 10:11 AM
datyip is offline
Spain
Joined May 2011
Thanks for your answer. Do I have to adjust the measurements or can I use directly your formulas in order to use the galv steel wire?
-Alex
Old May 23, 2011, 10:58 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Alex, saw this post from Sander ? Maybe it's the reason why the cp antennas don't work with the Lawmate Rx ??
http://www.rcgroups.com/forums/showp...postcount=1422
saucisse is offline Find More Posts by saucisse
Old May 23, 2011, 12:19 PM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
They do work, install a 100ohm resistor between video and ground on the vtx side.
Hugeone is online now Find More Posts by Hugeone
Old May 23, 2011, 02:45 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Hugo, you use a 100pF capacitor in series with the antenna centre connection to block the DC flow.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old May 23, 2011, 03:01 PM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
Gee, I can't believe this internet rumor is still circulating. The Facts are:
1) Lawmate Rx work fine with CP antennas. I have six lawmate RX and they all work perfectly with CP antennas and all other antennas I have tried.
2) Sander's post was a speculative response about what could be the problem if there was a problem (but there really is no problem). He thought the Lawmate RX might have +5v on the antenna output to power an external LNA which could be shorted if a closed loop antenna was used. This is an easy test to make: test the antenna input of the Lawmate with a voltmeter. You will find there is no DC voltage there.
What typically happens is that someone has a problem with their system or testing approach, blames a particular component and then makes a post. I know that facts have little impact on beating down internet rumors but I can't resist trying.
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old May 23, 2011, 03:10 PM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Sorry if my comment bugged you out that much! I don't read all post in here
OMM
Old May 23, 2011, 03:34 PM
careyer is offline
Find More Posts by careyer
member of TheBlindHawks
careyer's Avatar
Joined Feb 2011
Low range
Hi there
i've build one of those Skew Planar Wheel for my 910Mhz 800mw Hobbyking RX/TX Set but the result is extremely bad.
Though i tried to keep tolerances as small as somehow possible (<= 1-2mm) it does not give me more than 200m of range in direct line of sight. Tried all channels 1-4 (910-1040 MhZ) and channel 3 ist best. The Standard antennas even give me slighly more range and more robust signal. Any Idea what might be wrong?
Here's a pic of my two antennas:
P.S: 900M Mhz is the primary band for cellphones right over here. Might this affect the range that much? Cellphones are allowed to send 2W .... basestations about 8W.
careyer is offline Find More Posts by careyer
Old May 23, 2011, 05:15 PM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
hi
i am using the hobbyking 200mW 900mW system ... and the cells in my country operates on GSM which is also around the 900mhz area
i am using the cloverleaf on my vtx and SPW on my vrx ... so far my signal has been good up to 700m or thereabouts (checked on goggle map)... cannot fly far yet as i do not have RTH and OSD (but they are on the way) ... i have even flown my plane to within 100m of a cell tower with mild interference and between trees too
in theory u should have at least double my range
i see u have the SPW on both vrx and vtx ... u might wanna give the CL a try on your vtx since this combo is highly recommended
there was one time when i was getting no more than 200m of range so i did some checking ... apparently one of the wires have a cold solder joint on my vtx and cracked on the solder breaking up the signal intermittently ... making the range much much shorter than it should be ... u should try checking the solder points on your vtx/vrx just in case
QiW is offline Find More Posts by QiW
Old May 23, 2011, 05:16 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
If your in Europe or another country using GSM, I wouldn't use 900 mhz.. The cell towers can and likely will trash the signal if you get in their beam.
DarkHeli is offline Find More Posts by DarkHeli
Old May 23, 2011, 07:07 PM
QiW is offline
QiW
QiW
south east asia
Joined Mar 2009
hi darkheli
i have set my vtx closer to 1ghz ... so far the gsm 900mhz has not really affected me seriously ... unless i fly really close to the tower(s)
yes ... i know its a bad idea/choice of frequencies on my part
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
