Old Jul 06, 2014, 02:22 PM
Joined Nov 2012
Problems with Regen Discharge on PL8
I am trying to cycle a pair of 5s5000 25c packs on the PL8. I've done it before with a previous PL8 (that was defective and replaced by FMA), but this one won't do it. I have it connected to a car battery showing 12.3 volts, have the charge rate set at 6.5amps, and the discharge set at 18.5 amps, set at High Power. Whether I choose 2P or N makes no difference. Asking it to do 5 cycles, but it will only charge at 6.5A but the discharge peaks at 5A and just sits there for hours. If I tell it to Regen Discharge Only, same result. It seems to want to initially shoot up in discharge amps, maybe reaching 12 amps but quickly backs down to less than 3Amps then back up to around 5A.
Don't think the battery is at issue, since it is a frequently used deep-discharge Optima
Help is appreciated.
John
Astropattern is offline Find More Posts by Astropattern
Old Jul 06, 2014, 03:22 PM
Seattle
Joined Sep 2007
If you watch the Pb voltage on the charger or in they CCS, its most likely hitting 14.4v. This is where the charger will start throttling back the discharge current to prevent over charging the Pb battery.
A 5s discharging at 18 amps will end up being about 30 amps once it gets through the DC-DC converter. That's a pretty high rate for a Pb battery and will cause the Pb battery voltage to rise quickly. At this charge rate, the voltage rise will hit 14.4v even if the Pb battery is not fully charged.
You can add a load in parallel to the Pb battery to help bleed off the current. But don't leave it on or it will drain the Pb battery. Also top off the Pb battery when you are done to prolong its life.
Gregor99 is offline Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Discussion How to use regenerative discharge with full power ? wareck FMA Direct 1 Jun 29, 2014 12:01 AM
Discussion PL6 regen discharge issue tsymonds Batteries and Chargers 3 Apr 12, 2014 07:01 AM
Discussion Lipo IR,and discharge testing.pl8 and 308 IR comparisons.real world results ResultsRC Racing Boats - Electric 2 Mar 21, 2014 01:15 AM
Discussion Discharge rates with PL8 mewert Batteries and Chargers 7 Oct 01, 2013 10:03 AM
Discussion regenerative discharge: two PL8's into one battery? jv8 FMA Direct 10 Feb 14, 2013 06:53 AM
