Old Feb 23, 2014, 06:44 PM
United States, CA, Santee
Joined Mar 2003
Suggestions for Cheap Electric Combat Plane Kits?
Looking for an inexpensive electric combat plane kit that my buddies and I can order and build. Either full contact or streamer cutting combat is fine. A design that allows inexpensive swapping of electronic components onto a new semi-disposable airframe would be ideal. Between crashing and combat, we're likely to go through a bunch!
sstephenson is offline Find More Posts by sstephenson
Old Feb 25, 2014, 10:14 PM
Joined Sep 2003
hogwild
check out the hogwild electric combat plane made of coro plast.
http://www.electric-combat.com/
SpadHawk is offline Find More Posts by SpadHawk
Old Feb 25, 2014, 10:52 PM
Joined Mar 2003
Thanks SpadHawk. The Hogwild looks like a great little plane.
Old Mar 01, 2014, 07:24 AM
United States, MD, La Plata
Joined Jun 2012
A ton of easy scratchbuilt and kits offered in this thread...
http://www.rcgroups.com/forums/showthread.php?t=1012551
Icarusdanoob is offline Find More Posts by Icarusdanoob
Old Mar 01, 2014, 09:06 PM
United States, VA, Monroe
Joined Jan 2013
+1 on scratchbuilding
charliewilson is offline Find More Posts by charliewilson
Old Mar 06, 2014, 09:26 AM
Buzzsaw
Joined Mar 2007
http://www.rcgroups.com/forums/showthread.php?t=1061750
We have been building and flying this plane for years. It's cheap to build and lots of information floating around several groups. You can build this combat plane airframe for about $1.00.
dlw151947 is offline Find More Posts by dlw151947
Old Mar 06, 2014, 12:22 PM
Joined Mar 2003
Thanks for the link dlw151947! I really like that plane. Perfect for what I had in mind. That's one of the best threads I've come across.
Do you happen to have a list of the components that you recommend on this build (motor, esc, servos, prop)?
Old Mar 06, 2014, 01:06 PM
Buzzsaw
Joined Mar 2007
Motor-2408-21 might some at find at swap meets ,Prop-GWS-9070
Replacement Motor -AX 2308N,1800 KV. I think HK has them for $7.00.Use a GWS DD 9050 prop.
https://www.hobbyking.com/hobbyking/...cro_Motor.html
Battery- 2-cell, 7.4 volt, 1300 mah
ESC.18 amp will work.
https://www.hobbyking.com/hobbyking/...rammable_.html
Servos- 9 gr.
https://www.hobbyking.com/hobbyking/...cro_Servo.html
We tried to used everything cheap when flying combat.
Hope this helps.
Buzzy
http://www.wattflyer.com/forums/showthread.php?t=47556
Old Mar 07, 2014, 01:00 AM
Joined Mar 2003
Excellent! Thanks a million.
Old Mar 07, 2014, 08:38 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Cheap is all relative. If you are looking for combat planes that fly well and are making contact at high speeds and surviving take a look at these videos.
http://www.crashtesthobby.com/combat-videos.html
Lee is offline Find More Posts by Lee
Old Mar 07, 2014, 08:56 AM
Joined Mar 2003
I hear you Lee. I've had a Zagi wing in the past, and really liked it. I've never seen a plane take such a beating and then be able to dust it off and throw it back in the air. I want to have a couple options open, probably a wing and a scratch build foamie, to present to the guys that I fly with. We'll choose something and then go from there.
Old Mar 07, 2014, 11:00 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Gotta love the Assassin.
Assassin vs Brick Wall 3 12 (4 min 14 sec)
Old Mar 13, 2014, 09:36 AM
United States, UT, Roy
Joined Jan 2014
I have to agree with Lee. Just built my first combat wing (assassin) using a kit from crash test hobby and it's not just a foamie! This thing doesn't dent and because it's reinforced with extreme tape and 2 mil laminate it can take a beating. This was only my 2nd plane after a park flyer. The Assassin handled my learning curve with grace. First two launches were nose dives into my driveway. The next two were into the grass at the park before I learned to keep it in the air. After my first successful flight the landing resembled a lawn dart, except it bounced 10 feet. Picked it up and tossed it back in the air.
My favorite landing was with my kids around dusk. I was on approach, watching out for the kids, and accidentally bounced it off the top of a metal soccer goal stand. Everyone busted up laughing as it "pinged" off the top and rolled to a stop on the ground. without any repairs I took it out the next morning and tossed it in the air. Sure wish I had a video of that.
Anyhow, these planes are the reason I started RC flying. Cheap electronics, airframe like a B2.
-Nate
therevoman is offline Find More Posts by therevoman
Old Apr 28, 2014, 12:03 PM
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Check out my Nutball videos........... Cheap and fun.
RonJ
RonJ is offline Find More Posts by RonJ
Old Apr 28, 2014, 12:11 PM
Joined Mar 2003
Thanks Ron! Where do I find your videos?
Steve
Wanted Great Planes combat .25 ARF's Bob Paris Aircraft - Fuel - Airplanes (FS/W) 0 Jan 25, 2014 04:08 PM
Discussion Material for streamers for light combat rfk Electric Combat 11 Mar 17, 2013 05:23 AM
Wanted airframe for streamer combat txfly Aircraft - Electric - Airplanes (FS/W) 0 Jan 19, 2006 04:01 PM
Streamer Combat Plane? 13brv3 Sport Planes 12 Jun 22, 2002 09:22 PM
Which Planes for Streamer Combat? rrowley Sport Planes 1 Nov 13, 2001 08:32 AM
