Rockstar 48 Catamaran
Big, wide, and fast!
Pro Boat Rockstar Gas Powered 48 Catamaran
The Rockstar 48 inch catamaran is officially licensed by Rockstar Energy and comes equipped with a water-cooled Dynamite 26cc gas engine capable of speeds of over 40 miles per hour! Control of the Rockstar is made possible by the included Spektrum™ DX2E DSMR™ 2.4GHz radio system. Designed for optimum performance on a hand-laid, lightweight fiberglass hull the Rockstar 48 inch catamaran has the distinctive Rockstar Energy graphics.
Pro Boat™ Rockstar 48 Gas Powered Catamaran (1 min 12 sec)
  • Water-cooled Dynamite® 26cc gas engine capable of propelling the catamaran to speeds of over 40 MPH.
  • Large-scale servo with over 270 oz.-in of torque
  • Removable composite radio tray allows for easy maintenance and access to receiver and radio components
  • Inline rudder ensures the Rockstar 48 inch catamaran will turn with precision in both directions
  • Wide hull for better stability in turns and rough water
  • A centrifugal clutch helps prevent the prop from spinning while the engine is at idle. This added safety measure keeps your fingers and hands safe while being handled
  • The aluminum hardware has been anodized to match the Rockstar trim scheme and adds a level of durability for longevity
  • Superior Spektrum DX2E DSMR Radio System
  • Type: Catamaran
  • Length: 48 in (1219.2mm)
  • Beam: 17.3 in (440mm)
  • Weight: 20.2lb (9.16kg)
  • Hull Height: 9.5 in (241mm)
  • Hull Material: Hand-laid Fiberglass
  • Prop Size: 70mm Diameter, 1.5 pitch
  • Engine: Dynamite 26cc Gasoline Engine
  • Exhaust: Tuned pipe with muffler
  • Radio: Spektrum DX2E w/ DSMR 2.4GHz Technology
  • Driveline: Centrifugal clutch with flex shaft
  • Steering: Aluminum rudder w/ HD linkage
  • Servo: Spektrum WP 1/5-scale steering servo
Learn more here.
Last edited by Jim T. Graham; Dec 04, 2014 at 02:43 PM.. Reason: Rockstar 48-inch Catamaran Gas Powered: RTR
Old Dec 04, 2014, 03:55 PM
Kid at heart..
United States, TX, Houston
Joined Apr 2014
That's one sweet looking boat.
hangtheman is online now Find More Posts by hangtheman
Old Dec 04, 2014, 08:04 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
It's good to see that they decided to do away with the onboard starter that was used on the prototypes as these engines really don't need them. The Dynamite engine is made by CY/Sikk which is a better option than the Zenoah 260 that Proboat previously carried as it has more HP and RPM out of the box. Parts are easily available for it as most are interchangable with Zenoah or RCMK engines.
Including the Marine RX now is another huge plus.
Ron Olson is offline Find More Posts by Ron Olson
Discussion proboat 48" rockstar cat?!? angrycat Racing Boats - Electric 1 Aug 05, 2014 11:33 PM
News Pro Boat Rockstar 48 Paul Onorato Dock Talk 32 Feb 07, 2014 05:30 PM
News Horizon Hobby Joins Forces with ROCKSTAR Performance Garage! Paul Onorato Car Talk 0 Oct 28, 2013 03:37 PM
Build Log 48 inch Catamaran Build DepthsofHell Racing Boats - Internal Combustion 111 Jun 13, 2012 10:42 PM
Discussion !HELP! bow going up/down-Catamaran 48" hull racing boat reaching 50mph megacorp Racing Boats - Electric 4 Mar 25, 2012 03:32 PM
