Old Sep 09, 2013, 09:52 AM
Joined Sep 2013
Ornithopter information needed
Hello,
I am Robbe Derks, and toghether with two people we are working on an ornithopter design as a school project. Our design will be around 1.5m from tip to tip, so it will be very close to the CarbonSail ornithopter for example.
As we can't find much information about ornithopters this size, we would like to receive some information about the specifications and dimensions of these ornithopters. What we would like to know for now:
- How strong do the servos which control the tail movement need to be?
- What size / power and KV of brushless motor should be used and with which gear ratio? We figured out that the ratio will probably be between 1:100 and 1:1000.
- Is there any type of special control strategy needed to keep a steady flight?
My part of the project is mainly focused on controlling the ornithopter in a smart way. I am currently working on a custom PCB which will intercept and override the servo and motor signals with a clever algorithm to keep the ornithopter steady during flight with sidewinds, etc. so it will be easier to controll.
The data needed will be coming from an accelerometer, gyroscope sensor and a magnetometer to keep the bird facing the right way during flight.
The controller will also put the wings into 'gliding position' (leveled) when the throttle is released. This will be acheived with the help of hall sensors checking for magnets incorporated in the gears.
Any information / suggestions will be greatly appreciated.
Robbe Derks
DebboR is offline Find More Posts by DebboR
Old Sep 10, 2013, 02:58 PM
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Generally with the Kinkade ornis of that size we always recommend micro metal gear servos. Plastic-geared servos are adequate in the air, but when landing the heavy tail can snap down and strip the gears pretty easily.
I'm not a orni designer, but I've flown a bunch of them and in many different sizes. They're all quite steady in flight in low wind conditions. When it's windy it's a lot like R/C planes- the higher the wing-loading the more solid they are flying in wind. My Parkhawk is the smallest of my Kinkade ornis and flies the best in wind by far (has the highest wing loading and fastest flap rate). My Slow Hawk is the biggest, flies the slowest (lowest wing loading) and is affected the most by wind.
Is this orni going to be R/C or free flight? I can see the need for this in free flight, but R/C ornis are already quite easy to control, they're a lot like flying trainer planes.
They glide better if there's a slight "V" to the wings in glide-lock rather than level. It acts like dihedral does on a free flight plane.
This has been done before, someone on here was offering such a device for a while but I have no idea if the schematics were made available. You might try the search engine to see if you can find more info here.
Tres Wright is offline Find More Posts by Tres Wright
Old Sep 11, 2013, 10:50 AM
Joined Sep 2013
Hello,
Thanks a lot for this information. The orni will be mostly R/C controlled, but as our studies are highly technical orientated, we have also been given the challenge to let the bird do a free flight you described. It will probably be possible to flick a lever on the controller, so the software knows it needs to keep it's heading, ... It's just to make the project a little more complicated
My main concern about the orni at the moment is the size / power / KV-ratio the main brushless outrunner should have. I have no idea at all how much watts are required. We have actually done some vary raw calculations, and we figured out it will require about 300W. Is this figure anywhere near correct?
In other orni designs, we have found that the motors have a very high KV-ratio (around 5000kv). Why is this better? With a gear ratio of 1:100, this would result in a way too fast flapping speed, no (50RPM / V)?
Thank you!
DebboR
Old Sep 11, 2013, 11:33 AM
Patricia J B's Avatar
Joined Oct 2003
Hi,
Have you looked at this site?
http://www.ornithopter.de/english/index_en.htm
Cheers,
Patricia
Patricia J B is offline Find More Posts by Patricia J B
Old Sep 11, 2013, 03:08 PM
Joined Sep 2013
Originally Posted by Patricia J B View Post
Hi,
Cheers,
Patricia
Yes, I already found this site, but I don't think it tells me what I'm looking for. The only thing I'm after at the moment is an approximation of the power needed to keep an orni of 1.5m tip to tip in the air. And if I should use a motor with low or high KV (800kv - 5000kv).
Thanks anyway for answering,
DebboR
Old Sep 12, 2013, 10:58 AM
Joined Oct 2003
Here's another link . This is a paper on the 1.8 m wingspan
'Phoenix' built for control research by Jackowski.
'Design And Construction Of An Autonomous Ornithopter'
By Jackowski
M.I.T
http://groups.csail.mit.edu/robotics...ackowski09.pdf
Cheers,
Patricia
Old Sep 12, 2013, 01:39 PM
Joined Sep 2003
DebboR
I don't have a Kincade type ornithopter but I have read posts that said they need around 100 watts for the larger models. Its not a difficult measurement to make or compute from battery recharging but power data is hardly ever discussed or shared, so I suspect the power used is higher than advertised. Its a good idea to first build a smaller model and see what works.
Once you know the power and the flaps/sec required, you chose a kv, motor size and gear ratio combination that results in the lightest weight and best efficiency.
Good Luck!
George
Plantoflap is online now Find More Posts by Plantoflap
Old Sep 18, 2013, 12:05 PM
Forney, TX
Joined Mar 2002
No, it doesn't sound right unless the bird is going to be extremely heavy (and then you've got other problems). My Slow Hawk is around a 60" wingspan and at WOT pulls 91 watts, but in actual flying it rarely sees WOT.
I'm running an Axi 2208-26 on my Slow Hawk and Park Hawk, the KV is 1420. I run 3s on both.
Old Sep 18, 2013, 12:45 PM
Joined Oct 2003
The link I gave in post #6 gives details on how and
why they chose the motor, gear ratio etc
Help! Lost plane, need help to find it - with informations jvictorfc FPV Aircraft 8 Aug 15, 2013 07:16 AM
Help! Need information on a couple of articles Crist Rigotti Vintage & Old-Timer Designs 4 Apr 23, 2013 12:44 AM
Discussion Syma S026, I need some information hirschgans Coaxial Helicopters 3 Mar 10, 2013 06:51 PM
Discussion Need some advice and information JHawk19 Multirotor Talk 2 Feb 04, 2013 10:28 PM
Discussion HELP Velkom Giles g-200 kit information needed. marinefish666 Electric Plane Talk 0 Jan 12, 2013 04:29 PM
