Old Mar 14, 2012, 09:21 PM
Joined Sep 2006
LiPo's in parallel
What are the problems of running Lipos in parallel? I would like to run a 4s 4000mah 25C battery in parallel with a 4s 1800 mah 25C battery to minimize voltage sag without adding too much weight. I also plan on only using about 50% if capacity.
bob93447 is offline Find More Posts by bob93447
Old Mar 14, 2012, 11:27 PM
Joensuu, Finland
Joined Mar 2002
No problems at all. Just check that both packs are at same voltage before making the connection.
jkettu is online now Find More Posts by jkettu
Old Mar 15, 2012, 05:33 AM
Staffs, UK
Joined Nov 2003
Yep that will be fine. I've done parallel pairs even less alike without any problems. Just make sure the connections are all solid because you are adding extra wire and connections to the system.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 15, 2012, 08:56 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Should be fine however I would recomend checking each batteries indivual cell voltages after a flight and also charge seperately and note percentage of mAh replaced in each.
Charles
Old Mar 15, 2012, 03:29 PM
Joined Sep 2006
Thanks you all.
Bob
Old Mar 15, 2012, 10:56 PM
Joined Mar 2012
Originally Posted by bob93447 View Post
Thanks you all.
Bob
I use parallel charging ... Love it. Only way to charge if you wanna get a good session in imo
teamscon is offline Find More Posts by teamscon
Discussion is it ok to run lipo's in parallel? how much Batteries and Chargers 12 Feb 24, 2012 12:26 PM
Discussion Using lipo in parallel way question congcon97 Racing Boats - Electric 1 Feb 23, 2012 11:29 PM
Discussion Lipo in parallel, balancing tabs, charging SARCFAN Racing Boats - Electric 11 Feb 10, 2012 01:31 PM
Question Two lipo's parallel for flying a hexa bikertje888 Multirotor Talk 2 Oct 31, 2011 06:03 PM
LiPo's in parallel inedesca Batteries and Chargers 10 Nov 10, 2003 06:17 PM
