Old Feb 21, 2012, 06:38 AM
CaptainScott
Joined Feb 2012
Fiberglass help
Hello everybody, I ordered my plans from Don yesterday (Linda Jo) and getting a material list going.I see that most are glassing the hull, with what? 2 oz cloth? This is my first model boat so I'm sure I will have plenty of questions. Thanks any advice will be appreciated.
captainscott is offline Find More Posts by captainscott
Old Feb 21, 2012, 07:06 AM
Near Fleetwood, lancashire, UK
Joined Jun 2009
2oz cloth is far too heavy if you are just glassing inside a POF hull.....you'd find it very hard to lay between and over the frames it is so thick.
You'd be better with a couple of layers of surface tissue and resin.it's a thin gossomer type feel to it and gives (as it says) a very fine and clean surface.
neil.
nhp651 is offline Find More Posts by nhp651
Old Feb 21, 2012, 10:18 AM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
Most of us 'glass the outside, and for that, 2 oz (woven not mat) is great.
patmat2350 is offline Find More Posts by patmat2350
Old Feb 21, 2012, 01:39 PM
Joined Jun 2009
far too much work for me to rub down putting it on the outside Pat, especially chopped strand at 2oz weight. I'll stick to glassing a wooden hull on the inside, thanks.
Old Feb 21, 2012, 02:00 PM
CaptainScott
Joined Feb 2012
Yes that's what I am planning glass the outside
Old Feb 21, 2012, 02:53 PM
Veni, Vidi, Feci
patmat2350's Avatar
Motor City
Joined Dec 2004
But nhp, model boating is ALL about work!
Actually, this makes me think about another possible technique, wonder if anyone has tried this:
- Two planking layers, with glass in between
Where have we seen this? Well, Elco double-planked their PT boat hulls, and sandwiched a layer of glue-soaked canvas in between.
And the now defunct (I think) Equipage fixed their exploding model boat hull problem with a layer of glass in between two planked layers.
Benefits of doing this?
1. Only rough sanding of the fiberglass layer is needed... no need to take it to a perfect finish.
2. Still serves the function of avoiding leakage should planks shrink a bit.
3. Still serves the function of toughening the hull against bumps.
4. More easily allows for visible plank lines, should you want to do this for scale appearance.
Whaddya think?
Old Feb 21, 2012, 04:41 PM
Joined Jun 2009
a very interesting concept Pat.......I don't think though that I could work to that precission to get a sheet of grp in between two layers of timber planks without a lot of sanding.......and I always say why make work for yourself if you can find an easier solution.
neil.
Old Feb 21, 2012, 05:02 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Neil,
I don't think Pat has a sheet in mind, but just a layer of glasscloth and epoxy.
I do agree with Pat, modelboatbuilding strongly resembles work..., but I like it more than my day job.
With a little planning, glassing a hull doesn't take a lot of time, it's the curing of the resin that takes much longer...:
http://www.rcgroups.com/forums/showthread.php?t=1551192
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Feb 21, 2012, 05:07 PM
Joined Jun 2009
I didn't mean a sheet as such, but I call a leaf of paper a sheet.....suppose it's just my way of saying a "layer of"
Old Feb 21, 2012, 06:07 PM
United States, IL, Chicago
Joined Jul 2011
I just glassed my first boat kit using Pacer Z-poxy resin and Sig 1.5 oz/sqyd cloth. You can see pictures of my build under the build log titled, "Garwood Speedster - My first kit".
heavymeasure is online now Find More Posts by heavymeasure
Discussion Help with EPS and fiberglass CoolGod Foamies (Scratchbuilt) 5 Jan 14, 2012 10:05 PM
Help! Racing Runabout - Fiberglass Help brett_fla Scale Boats 3 Oct 11, 2011 01:40 PM
Discussion Need help with 3oz fiberglass cloth FLAME747 Composites Fabrication 7 Sep 13, 2011 11:50 AM
Discussion Fiberglass help rcbeginner1 The Builders Workshop 8 Jul 21, 2011 12:20 AM
Discussion fiberglass cowling help rotccapt Composites Fabrication 1 Apr 26, 2011 01:30 PM
