Old Jan 27, 2012, 01:20 PM
Joined Mar 2008
What makes the best building board?
I have used kitchen counter top covered in like a plastic covered foam board but it's not very durable and pins come out easy, what's the best thing you've found?
rbwindover is offline Find More Posts by rbwindover
Old Jan 27, 2012, 02:49 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
I use a 30"x78" flush panel door with a piece of what my local timber supply call"pin board" on top.It's a hard fibrous board,3/8" thick,takes and holds a pin well.I cover it with decorators lining paper as the surface is absorbent and can swell if you have a dammit moment with glue etc
Stupot46 is offline Find More Posts by Stupot46
Old Jan 27, 2012, 03:12 PM
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
I used to use a flat, plastic covered shelf from a DIY store with some 13mm cork sheet stuck to it using contact adhesive.
These days I just use a Great Planes building board!
DeeBee1 is offline Find More Posts by DeeBee1
Old Jan 27, 2012, 05:44 PM
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
I have seen several folks talk about using a flat panel door, covered in metal so that magnets could be used in the building process.
Sounds like a great idea and something I am going to look into when I re-organize my hobby room.
mthomas is offline Find More Posts by mthomas
Old Jan 27, 2012, 05:54 PM
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
If they ever get them back in stock, Guillows balsa building boards. I've got one 36" and one 48". Had them for several years now, still flat despite a few house moves and they sat in storage for several months back in 2010.
One good trick I learned - mine can be hinged together. I sit them on my building bench, prop one up to a wing's dihedral angle and build the complete wing out from the dihedral brace and centre structure. Beats the heck out of joining a pair of completed wing panels - took me long enough to figure that out too.
Tower Hobbies do something similar in balsa too.
D
Dereck is offline Find More Posts by Dereck
Old Jan 27, 2012, 06:31 PM
wizard of odd's Avatar
Australia, WA, Kalgoorlie
Joined Apr 2011
I use the same as Stuart Annat, except I paint the fibre board with two thick coats of latex house paint and drape it over with plastic sheet from the dressmaker's shop (blasted cyano spills!). That method has served me well for years. Recently I collaborated with the forum sponsor to get a building jig/ building board laser cut- to be used for smaller projects- with the ability to tab two or more boards together for longer or wider projects. These will get dense cork sheeting just like DeeBee's board.
wizard of odd is offline Find More Posts by wizard of odd
Old Jan 27, 2012, 07:32 PM
Joined Jul 2006
I like 2'x4' ceiling tiles.
They can be stood on their long side and stacked against the wall so that while I wait for the glue to dry on that board (say a wing), I can work on the fuselage on another 2'x4' piece.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jan 28, 2012, 05:27 AM
Joined Mar 2008
What type of ceiling tiles....like the styrofoam ones?
Old Jan 28, 2012, 08:03 AM
yel914's Avatar
SLC, Ut
Joined Apr 2010
I use a magnetic building board. It's infinitely adjustable and it's the last board I'll ever need.
yel914 is offline Find More Posts by yel914
Old Jan 28, 2012, 11:17 AM
Joined Jul 2006
I think they are made out of some kind of compressed paper product? All the ones I've seen seem to be made of the same material.
Old Jan 28, 2012, 02:42 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The regular commercial ceiling tiles are made from a funny sort of fibrous compressed material. It tends to crumble easy if heavily handled. But it's just the right sort of stuff for building boards to hold pins well. I believe that the old term for this material was "donachonda board".
I like to glue the ceiling tile material to a piece of 3/4 MDF board. The MDF is normally very flat and stable while the CT is a bit too flexible on its own. As a sandwich it's fantastic. These boards will work out for a long time and after some two or three dozen projects when glue spotted and chunked out so badly that they are ruined can be easily discarded and replaced with a clear conscience. I'm not normally a big fan of spray contact cements but for joining the ceiling tile material to the MDF it's the perfect product. Otherwise the ceiling tile would soak up FAR too much contact or other glue if applied with a brush or trowel.
Keep the tile and MDF away from water. THis includes water based glues. Bad things happen when either material gets near water.
BMatthews is online now Find More Posts by BMatthews
Old Jan 28, 2012, 04:26 PM
AMA 937634
United States, AK, Anchorage
Joined Jan 2010
I use a hollow door and then a Great Planes building board over that for pinning.
My building board warped a bit but I've had some pretty dramatic humdity swings here so it's just become something I check before I begin building.
I'd like to move to a magnetic board but I haven't found a decent piece of metal here.
-Mike
Stone1295 is online now Find More Posts by Stone1295
Old Jan 28, 2012, 08:48 PM
Joined Jul 2007
I use a hollow core door covered with a sheet of drywall. It takes pins well and is a true surface providing the door is good, also it's cheap,readily available, and easy to replace when need be.
Jess
wolfyd2 is offline Find More Posts by wolfyd2
Old Jan 28, 2012, 09:45 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
sheetrock
because it costs 3 bucks for a massive sheet. you can be completely un-caring with them and you're out nothing
Toysrme is offline Find More Posts by Toysrme
Old Jan 28, 2012, 10:45 PM
United States, VA, Forest
Joined Nov 2009
Solid core door with 3/32 metal top for use with magnets. Spills or glue scrape up easy and as stated earlier, it is infinitely adjustable. Last board you will ever need. Frame needs to be strong. Here it is in action with an electric foam job.
John
Rubbernecker is offline Find More Posts by Rubbernecker
How best to store my building board ? albertofkent The Builders Workshop 0 Mar 31, 2005 12:43 PM
What company makes the best Hi-Starts? Norbert99 Electric Sailplanes 7 Feb 26, 2002 08:38 AM
UK - What's on the building board seeing as we can't fly in hurricane force winds! Steve Wrona Parkflyers 28 Feb 04, 2002 08:58 PM
