Old Dec 16, 2002, 03:44 PM
RMason is offline
Find More Posts by RMason
A Few Sandwiches Shy
RMason's Avatar
Orlando, FL
Joined Jun 2001
Mustang with 4 blade prop
Just got the 4-blade GWS prop for the P-51. I modified the existing spinner plate to fit.
Motocalc says
GWS "D" gearbox 4 blade 10X8
7.7amps
Static 14oz. (.91%) 3748rpm
Best L/D 7.1oz (.46%) 4212rpm
GWS "C" Gearbox 2 blade 10X8
7.9 amps
Static 11.8oz (77%) 4815rpm
Best L/D 6.9 oz. (.45%) 5065rpm
You get the same amp draw with better climb and vertical maneuvers without sacrificing any top end speed.
BTW - with a miniAC 1215/16, the "C" gear and 4 blade prop you get over 16oz. thrust for unlimited vertical (that's the next step)
Plus it looks INCREDIBLE !!!!!!!!!!!!!!!!!!!
Judge for yourself
RMason is offline Find More Posts by RMason
Old Dec 16, 2002, 03:48 PM
RMason is offline
RMason's Avatar
Orlando, FL
Joined Jun 2001
Flight tests confirm what Motocalc says. Might even be just a little bit better than Motocalc. Great climb, better vertical and just as fast.
Slows down faster because of all that prop windmilling out there. Easier landings because of the steeper approach.
Here's a more normal shot.
Old Dec 16, 2002, 03:53 PM
RMason is offline
RMason's Avatar
Orlando, FL
Joined Jun 2001
If you are thinking of using the "C" gear with the 4 blade - don't.
It really gets amp hungry at 9 amps and there is NO performance increase.
I'm really having too much fun with my camera.
Old Dec 16, 2002, 03:57 PM
GForceStress is offline
Find More Posts by GForceStress
Oxymoron: Rap Music
GForceStress's Avatar
Upstate NY
Joined Sep 2002
It looks very good for a GWS. Great work GWS and RMason. How does it handle low speed landings? I know most of the warbirds will just go into a dive or spin.
GForce
GForceStress is offline Find More Posts by GForceStress
Old Dec 16, 2002, 04:03 PM
roguewolf is offline
Find More Posts by roguewolf
MEDIC!!!!!!!
roguewolf's Avatar
Near Fresno, California
Joined Sep 2002
That's it, I've been thinking about getting a gws P-51 for a while, but this is really great looking.
My LHS just got six of these in stock and I even have a spare "D" box laying around.
Time to go order a propellor and grovel to the wife......but honey, I really need all of these planes....
roguewolf is offline Find More Posts by roguewolf
Old Dec 16, 2002, 04:07 PM
RMason is offline
RMason's Avatar
Orlando, FL
Joined Jun 2001
GForce -
It flies much better than the Zero.
As long as you don't have more than the recommended elevator throw, it likes low speeds just fine. Keep the CG near the forward part of the range and it is hesitant to tip stall. Doesn't mean it won't if you're careless, but it won't bite you unexpectantly.
Actually it flies like my .60 slimer TF Spitfire come to think of it.
Landing is the trickiest part. I bring it in a little fast and hold it just off the ground to let the speed drop off, and it settles to the ground pretty as it could be. The last part of the rollout is something else, the flimsy gear legs want to fold under with any sideways force and the Mustang ends up on it's nose. Solved that by making my own gear legs.
Rob
Old Dec 16, 2002, 04:16 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
That's the best looking Mustang I've seen yet, and not just because of the prop. Nicely done!
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Dec 16, 2002, 04:28 PM
RMason is offline
RMason's Avatar
Orlando, FL
Joined Jun 2001
Thanks Dreamer,
Your Mountain Models Planes are an inspiration.
I can't wait for my MiniAC
Rob
Old Dec 16, 2002, 06:53 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Gosh that looks great! But please make some doors for it to finish it off!!!!
Fred Bronk is offline Find More Posts by Fred Bronk
Old Dec 16, 2002, 08:09 PM
boom is offline
Find More Posts by boom
NiCd + Mabuchi 550 was da bomb
NY USA
Joined Apr 1999
How come in two of the pictures, it looks like the tail wheel isn't touching the ground?
boom is offline Find More Posts by boom
Old Dec 16, 2002, 08:38 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
If you look closley they are touching, it's just the angle of the picture.
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Dec 16, 2002, 08:44 PM
simano is offline
Find More Posts by simano
Jungmeister 55
simano's Avatar
Orlando Herndon, Florida, United States
Joined Sep 2002
Looks great with that 4 blade Rob!!...and good paint job on the prop too. I like the specs and performance as you report it from your tests today. I made 4 flights today with the C gear and it was great. I also have the D gear so, I'll get the 4 prop next...
Gerry.
simano is offline Find More Posts by simano
Old Dec 16, 2002, 10:01 PM
boom is offline
NY USA
Joined Apr 1999
I see,
The angle made the shadow of the wheel dissapear.. so it looked weird.
Old Dec 17, 2002, 12:40 AM
RMason is offline
RMason's Avatar
Orlando, FL
Joined Jun 2001
Thanks all for the compliments,
I can't take all the credit, GWS designed a good plane. They took all the complaints from the Zero and made an exceptional plane. If the Me 109 and the Spitfire are of the same caliber I'm in trouble.
Fred - some gear doors are in the planning stages. If I put the Brushless in it, I'm gonna put some retracts on it. If not, then the gear doors will still go on.
Gerry, Carlos - See you Sunday for some great flying.
Rob
Gerry - next time ou go out - give me an E- Mail, It's only 5 min. from my house
Later,
Rob
Old Dec 17, 2002, 12:57 AM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Rob -
Are those wheels stock?
Great looking bird...got to get the Chech Mustang done, so I can start on my GWS 'Stang.
Terry
temacc is offline Find More Posts by temacc
