Old Jan 26, 2007, 12:31 PM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Something Curious
Some 45 years ago there was a plan for a free flying gyro in a german magazine. It was a small gyro with something like a 1/2A engine and not much of a fuse.
What I disticly remember was the rotor construction because I never quite understood how it was supposed to function. The blades had axles glued into them and these axles could rotate in their holders. Out of the front edge of the blades came a piece of piano wire which pointed some 30 to 40 downwards and had a liitle weight at the end. The blades with the weight were prevented from just turning downwards by a little stopper. I hope the attachment is able to lift the fog of my description.
Has anybody an idea how this could work?
Jochen
JochenK is offline Find More Posts by JochenK
Old Jan 26, 2007, 01:00 PM
rotorheid is offline
Find More Posts by rotorheid
Closed Account
Joined May 2006
Hi Jochen,
First thoughts, looks like the old constant speed propellor theory I was supposed to learn in ' 74, where the ATM (aerodynamic turning moments) are in opposition to the CTM (centrifugal turning moments), but that was for a powerdriven rotary aerofoil/airfoil , I need to think on this in the Autorotative sense. I'm sure some one will have the answer, may be if you get the designers name you can trace it. Yes very curious indeed.
regards
Al(T)
rotorheid is offline Find More Posts by rotorheid
Old Jan 26, 2007, 01:19 PM
iter is offline
Find More Posts by iter
High-power Rocket Gliders
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
Did the article say how well the design flew?
Ari.
iter is offline Find More Posts by iter
Old Jan 26, 2007, 01:41 PM
mnowell129 is offline
Find More Posts by mnowell129
I'm not as bad as they say.
Joined Nov 2004
An idea that's still around.
http://www.coxmodels.com/prodinfo.asp?number=004421
It works by virtue of the fact the objects try to spin flat due to centrifugal force. In the diagram R1 is smaller than R2, hence the weight which is free to twirl on what I would call the feathering axis, will turn to be at the largest radius.
The higher the rpm the more the weight tries to pull flat and pull pitch into the blades. As the blade pitch increases the rpm slows and gravity acting on the weight pulls the pitch out, somewhat like an automatic pitch regulator.
On the cox helicopter it pulls the blades to positive pitch when the motor is running so the blades help the climb. When the engine quits and the rotor slows the blades automatically de-pitch to the autorotation setting. I assume the stop is there to set the lowest pitch allowed and prevent a fully feathered position that won't start spinning by itself.
ain't physics fun?
mickey
mnowell129 is offline Find More Posts by mnowell129
Old Jan 26, 2007, 02:46 PM
JochenK is offline
JochenK's Avatar
Joined Jan 2005
Ari,
that was in the middle of the last century: I've simply forgotten.
Mickey,
at last. I've never thought about the increased radius by the forward movement of the weight. Thanks.
Jochen
Old Jan 27, 2007, 01:08 AM
Scotth72 is offline
Find More Posts by Scotth72
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Wow. I had an Airwolf model of one of those when I was a kid. Wouldn't fly unless the motor was tuned just right. It also fell out of the air when the motor quit. Ah, the memories.
Scotth72 is offline Find More Posts by Scotth72
