Old May 11, 2002, 05:47 PM
Capslock is offline
Find More Posts by Capslock
Big Member
Capslock's Avatar
San Francisco, CA
Joined Nov 2001
Issues with Dymond Super Turbo Charger.
I'm having some trouble with charging my battery packs. I have 2 8-cell 2400Max packs from SR Batteries, and 2 8-cell 1900SCR packs from Hobby Lobby.
It seems to me that my Dymond Super Turbo Charger is not fully charging the packs. Sometimes it takes 30 minutes or more, and I get a peak voltage on the packs of about 12.4 volts. Other times, it takes 10 minutes and I get a peak of 11.8 or so volts. It seems to make a big difference in flight performance.
Why would this be happening? All the packs are fairly new, and I've used both the Auto charging and manual settings. I usually cycle using the discharge/charge settings.
Capslock
Capslock is offline Find More Posts by Capslock
Old May 11, 2002, 05:50 PM
Stregone is offline
Find More Posts by Stregone
Stregone's Avatar
Manassas, VA, USA
Joined Feb 2002
Brand new packs sometimes take a few charges to kind of settle down before they will peak correctly. If they aren't brand new try charging at lower amps. Report back if this works or not
Stregone is offline Find More Posts by Stregone
Old May 11, 2002, 05:55 PM
Capslock is offline
Big Member
Capslock's Avatar
San Francisco, CA
Joined Nov 2001
Good call
I'll try the lower amps. Right now I'm experimenting with the irrational theory that I get different results by using just the "Charge" rather than "Dis/Charge".
I'll give the lower amps thing a try for sure, and report back. Gotta do it later tonight though, as I have a BBQ to go to.
Capslock
Old May 12, 2002, 03:21 AM
erashby is offline
Find More Posts by erashby
Flying Free
erashby's Avatar
Utah
Joined Aug 2001
Are you using the temperature cord? I found with my charger that the temp cord needed to be unplugged and plugged back in to reset sometimes.
erashby is offline Find More Posts by erashby
Dymond Super Turbo Charger dave_lilley Electric Plane Talk 26 Apr 24, 2002 02:33 PM
Dymond Super Turbo Charger dave_lilley Site Chat 0 Feb 24, 2002 04:13 AM
c/10 charging with Dymond Super Turbo ryancramer Power Systems 22 Feb 02, 2002 03:15 AM
WooHoo! I got my Dymond Super Turbo Charger rtideas Electric Plane Talk 30 Jan 30, 2002 07:30 AM
Dymond Super-Turbo charger gjestico Electric Plane Talk 13 Dec 27, 2001 12:36 PM
