Old May 21, 2016, 08:28 PM
jiysh is offline
Find More Posts by jiysh
Joined May 2016
Motor vibration with oneshot
Hi guys,
not sure if this a known/normal side effect with oneshot, but with my configuration enabling oneshot induces motor vibration.
It's hard to describe, but when holding the motor in my hand it feels like it's not really running smooth, there are periodic "knocks" that cause vibration.
I only noticed it coincidentally, it still flies fine with oneshot enabled.
Initially I suspected that this also causes higher temps, but I just measured temperature on both motor and escs with an (imprecise) EX230 IR thermometer and couldn't confirm any significant difference. At least not when "only" going up to 50% throttle.
I tested this with the following setup:
- Cleanflight 1.13RC0, but it also happens with Betaflight 2.7
- BlHeli 14.5, dither 7, light dampened, medium timing
- happens definately with throttle 0%-50%, it get's less noticeably with higher rpms.
- Diatone 2206-2000kv motors
- Diatone TY20 ESCs (atmel, similar to hk blueseries)
And because I'm really having troubles describing this phenomenon here's a video showing it:
Oneshot motor vibration (0 min 21 sec)
Sorry for the sub par production quality and me not being able to hold my hands still . But I think the video is sufficient to show that the bottom set up runs a lot less smooth.
Cheers for any input on this.
jiysh is offline Find More Posts by jiysh
Discussion BLHeli OneShot, WiiEsc OneShot, SimonK OneShot RS2K Multirotor Electronics 3490 Jun 22, 2016 03:09 PM
Help! Quad motors not spinning when enabling Oneshot on Cleanflight. Please help. erick3150 Multirotor Electronics 10 Mar 27, 2016 09:15 PM
Discussion Orange 615X with Naze32 and 20A Afro Race Spec with Oneshot ESC Nihilistic Multirotor Electronics 2 Feb 29, 2016 08:26 AM
Question Did I kill the motor output on my Naze32 by enabling oneshot with the ESC plugged in? fahrvergnuugen Mini Multirotors 12 Aug 16, 2015 04:26 AM
Discussion Best motors/props for Tarot 250 3-4S racer with KISS 18a ESC's & oneshot Ari33 Multirotor Power Systems 0 Mar 15, 2015 02:32 PM
