Old Jul 27, 2013, 10:59 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
tp motors ?
http://www.tppowerusa.com/motors/inr...tp-29xx-series
any good ?
sebbe is offline Find More Posts by sebbe
Old Jul 27, 2013, 02:57 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Interesting.
Never even heard of them before, and they dont look like to be any other manufacturers product.
jackosmeister is online now Find More Posts by jackosmeister
Old Jul 27, 2013, 08:31 PM
xzd is online now
xzd
Find More Posts by xzd
xzd
Joined Jul 2004
It seems that they are better known for the boat guys. http://www.youtube.com/results?searc...be.r0XkrgxVgt4
I bought myself a 2940/2200kv as a 5s motor for my Jolt before I go for something expensive. Just did some initial test and first impression is pretty good.
It weights 183g (182g listed). IR was measured to be 16.2/16.4/16.3mOhms (16mOhms listed) between each two of the three wires. The good thing is the no load current is lower than the crappy motors with cheap laminates. I got 1.25A with 3s and 1.5A with 5s. Both packs are fully charged. The results is comparable to a Neu 1115/2D, which is of similar kv. I will post more when I finish building my plane.
xzd is online now Find More Posts by xzd
Old Jul 27, 2013, 08:45 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
That's good to hear! I already have my legs for my Jolt, but I might have to pick one of these up when the Rifle 1m comes out
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Jul 28, 2013, 01:50 AM
magrinsi is online now
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
How i can measure the ir of a motor?
magrinsi is online now Find More Posts by magrinsi
Old Jul 28, 2013, 02:07 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
does a 29.1mm motor(which these are), fit any pylon/F5D that is made for 28mm motor??
Old Jul 28, 2013, 09:19 AM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
It should fit in that Plasma II you are interested in..
stanordave is offline Find More Posts by stanordave
Old Jul 28, 2013, 10:36 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
,,,, was interested in....
Old Jul 28, 2013, 10:52 AM
xzd is online now
xzd
xzd
Joined Jul 2004
You can easily measure the IR with a constant current source and a voltage meter. You can use your Lipo charger for the CC source. Just put the motor in series of an empty battery and set a charging current. Then read the voltage drop across the motor wires using the mV range. Make sure the testers in the voltage meter contact the motor wires directly to eliminate the contact resistance. Then you can get the IR by dividing the voltage drop by the charging current. The accuracy of the test depends on the accuracy of the voltage meter and the CC source. I usually series a current meter with the motor for the accurate reading of the current when using a charger as a CC source.
The TP motor fits in my Jolt.
Sold Thunder Power TP-1010C charger with TP-210V balancer in box Rick Team Horizon Aircraft - Electric - Batteries & Chargers (FS/W) 4 May 02, 2013 11:58 AM
Sold Thunder Tiger TP-1010C charger + TP-205V balancer neavissa Aircraft - Electric - Batteries & Chargers (FS/W) 4 Apr 15, 2013 04:34 PM
For Sale Thunder Power TP-425 Charger / TP-205 Balancer cap_sized Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2013 08:06 PM
For Sale Various motors/TP/UH-HC Motors for sale bass3587 Aircraft - Electric - Power Systems (FS/W) 4 Oct 28, 2007 05:06 PM
FS: Himax motor, GWS Motors, GWS Gearboxes, HS-55 Servo and TP 2S 1900 Lipo etc. ScYcS Aircraft - Electric - Airplanes (FS/W) 45 Jul 28, 2004 10:08 PM
