Old Nov 24, 2012, 09:15 PM
Ozvooky is offline
Find More Posts by Ozvooky
Concorde :D
Joined Jan 2012
Help!
Blade MCX Plane mod
Hi all I have a blade MCX but I'm going to turn it into a plane. Since the heli has two motors and two servos, I'm going to try to make it into a mini little plane that is 3 channel. If anyone has attempted to do this with any other helicopter feel free to post your pics here Thanks
Ozvooky is offline Find More Posts by Ozvooky
Old Nov 24, 2012, 09:32 PM
Denile is offline
Find More Posts by Denile
M16 CIII/AR15/FN 2000 and PS90
Denile's Avatar
United States, AR, Waldron
Joined Jan 2005
I was wondering same but as the blade turns by varying blade speed can this be dissabled and still be able to use both motors in a antirotating manor with the other two channels being rudder or aileron and elevator. I was hoping simply removing gyro would make this possible.
Denile is offline Find More Posts by Denile
Old Nov 24, 2012, 09:53 PM
Ozvooky is offline
Concorde :D
Joined Jan 2012
I'm not to sure... I might try to somehow use 1 motor
Old Nov 24, 2012, 09:55 PM
C-ME-FLY is offline
Find More Posts by C-ME-FLY
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
First u have to pop the cover off the gyro. It is the little silver case attached to the brick. Don't remove the whole thing because The brick won't work after. There is a mod somewhere on here for it. just look up how to disable gyro on bmcx. I'm getting readdy to build a micro stagger bee with twin motors. Hope that helps. When I yet to it i will do a pictorial on how to do it if you are still interested.
C-ME-FLY is offline Find More Posts by C-ME-FLY
Old Nov 24, 2012, 09:59 PM
Ozvooky is offline
Concorde :D
Joined Jan 2012
I'm a bit confused.. Why should we disconnect the gyro? Can you post a vid on how to o so?
Old Nov 24, 2012, 10:02 PM
C-ME-FLY is offline
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
If u don't. u will have to mount the brick upright. In turn a lot of weight to add for bellcranks. Let me find the post on how to disable gyro.
Old Nov 24, 2012, 10:07 PM
C-ME-FLY is offline
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
http://www.rcgroups.com/forums/showthread.php?t=1344415
Old Nov 24, 2012, 10:19 PM
Ozvooky is offline
Concorde :D
Joined Jan 2012
A pictorial would be great Also could I use other motors that have two pins to plug it in the motherboard? And does a brick mean motherboard?
Last edited by Ozvooky; Nov 25, 2012 at 06:18 AM. Reason: I didn't want to double post
Old Nov 25, 2012, 08:45 AM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
I've run many mCX bricks with the gyro litterally popped off. No need for additional mods or jumpers. See my F-35 thread for details: http://www.rcgroups.com/forums/showthread.php?t=1768778
-Adam
AJWoods is offline Find More Posts by AJWoods
Old Nov 25, 2012, 09:01 AM
Ozvooky is offline
Concorde :D
Joined Jan 2012
Cool! What servo pushrods did you use? And for the motors, can you use any motors that have 2 pins?
Old Nov 25, 2012, 10:07 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
I used a pushrod set from the UM T-28. For motors I used two of the Airhogs 7mm motors with stock props. You can use pretty much any sub 7mm brushed (2-wire) motor. Larger motors will overload the stock speed controls, and cause the motors to cut out.
-Adam
Old Nov 25, 2012, 02:55 PM
Ozvooky is offline
Concorde :D
Joined Jan 2012
Ok cool thanks Would this motor work? http://www.micronwings.com/Products/...hm/index.shtml
Last edited by Ozvooky; Nov 25, 2012 at 03:01 PM. Reason: I didint want to double post
Old Aug 23, 2013, 12:47 AM
boa2110 is offline
Find More Posts by boa2110
United States, AZ, Tucson
Joined Apr 2012
I built this 36" glider. Removed the gyro and used a 7mm motor. AUW 30g
micro glider (0 min 48 sec)
boa2110 is offline Find More Posts by boa2110
Old Oct 09, 2013, 10:14 AM
boa2110 is offline
Joined Apr 2012
now in a micro stingray. 24g AUW
Discussion Blade mCX mods talbot Coaxial Helicopters 1412 Nov 22, 2015 09:21 PM
Question Blade MCX heli brick for micro plane (disable gyro how?) tippytoe Micro Ready-to-Fly 2 Jul 15, 2012 07:22 PM
Discussion Blade mCX SolidWorks models and Mods JonJohnston Coaxial Helicopters 6 Jan 06, 2009 07:18 PM
Discussion Blade mCX charger mod ?question? Ace.Nerd.07 Coaxial Helicopters 1 Jan 02, 2009 07:12 PM
Discussion Blade CX2 to MCX look-a-like mod sarawnty Coaxial Helicopters 1 Jan 02, 2009 06:37 PM
