Old Oct 08, 2012, 04:50 PM
A1CpuntacanaDr is offline
Find More Posts by A1CpuntacanaDr
A1CpuntacanaDr's Avatar
United States, CT, Plainville
Joined Jan 2012
What did i did wroong !!!!!!!!!
I been flying on this set up all sumer recently i order a turnugy nano tech 1000mah 25-50 c 4s whent out to the field and this happend dont know why Did the battery was to much for the esc ?
A1CpuntacanaDr is offline Find More Posts by A1CpuntacanaDr
Old Oct 08, 2012, 06:41 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Those are rated for 4S and that fan should have been fine on it. It looks like the capacitor on the battery connectors end might have popped or exploded.
Those usually have a pair of lead that are for an on/off switch, were those in use? Or was there any chance they got shorted out on one of the battery leads?
You had been using it for a while and the connectors were OK too?
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 09, 2012, 04:10 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
What was the previous battery you flew on ?, including the 'C' rating.
If you had previously been flying around the current limit of your system, and you then installed a battery with a much higher 'C', the volts and current can rise quite a bit.
What did your wattmeter show as the current and volts at WOT ?. (You do have a wattmeter ??).
eflightray is offline Find More Posts by eflightray
Old Oct 09, 2012, 12:51 PM
rvlevy7 is offline
Find More Posts by rvlevy7
rvlevy7
rvlevy7's Avatar
United States, NJ, Clinton Township
Joined Sep 2012
Look alike high volt battery over esc or common short. If caps reversed caused burn out.
Check voltage battery or esc's inform, cap if reverse (backward)
and polarity connectors
rvlevy7 is offline Find More Posts by rvlevy7
Old Oct 09, 2012, 06:34 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Huh?
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Oct 10, 2012, 06:48 AM
rvlevy7 is offline
rvlevy7
rvlevy7's Avatar
Joined Sep 2012
Originally Posted by Mark Wood View Post
Huh?
mw
Sorry that language seem not clear to you
high voltage battery mean wrong volt to esc. What esc acceptable volt range (I.E. 5-12 volt).
Rare error manufactory installed capacitor backward.
If wrong polarity connectors
Connector, or circuit short that easy troubleshoot
better understand?
Bob
Old Oct 10, 2012, 08:42 AM
Jack
USA, ME, Ellsworth
Joined May 2008
He said he had been flying the set up all summer long so I assumed that it was more a failure of the capacitor in use or maybe a short developed.
It would be interesting to hear if the problem stopped when he throttled back. That way we might be able to tell if the load on the ESC was the problem and throttling back stopped it or if there was a short that continued until if broke the connection.
I tend to think that it was not ESC overload or the failure would have been different. I'm thinking more of shorts and capacitor failure. The ESC was rated for use with 4S.
Jack
Old Oct 10, 2012, 11:57 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
better understand?
Bob
lol
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Oct 12, 2012, 01:43 PM
cliffh is offline
Find More Posts by cliffh
Gustavus, OH
Joined Oct 2007
Here is one posibility. Motors don't always fail suddenly. If operated at or past their heat dissapation limit, they overheat. This overheating may be tolerated for a while. Each flight causes some insulation breakdown in the windings until a couple windings short out....causing more current....causing more heating....until the "magic smokes escapes".
On a motor where you can see the windings, you may notice the color of the insulation on the windings getting darker and darker with age.
Installing a NEW battery would have resulted in higher voltage than the motor has seen in a while....as the original battery will have increased internal resistance with age causing the voltage to drop a bit. When you put the new battery in the plane, the increased voltage caused higher heat in the motor pushing it (with the heat damaged insulation) over the edge and POOOOF.
A watt meter MAY have prevented this by making sure your set up was operating within limits.
Then again, crap happens and maybe something else just shorted out
Sometimes we never do find the cause.
So in the end, I may not have helped a bit
Cliff
cliffh is offline Find More Posts by cliffh
Discussion What did I do? Syner01 Bergen County Silent Fliers 6 Apr 06, 2012 12:14 PM
Discussion What Did I Fry?!?! Rikterscale Batteries and Chargers 15 Mar 31, 2012 07:20 PM
Discussion OK, what did I buy? Hemikiller Fuel Heli Talk 2 Mar 27, 2012 08:06 AM
Discussion how do I start,and what did I do? epoxyearl Trader Talk 10 Mar 18, 2012 10:22 AM
Discussion What did this come from?? tlh101 Power Systems 2 Mar 03, 2012 02:59 PM
