Old Sep 07, 2012, 03:18 PM
Creative78 is offline
Find More Posts by Creative78
Creative78's Avatar
Italy
Joined Dec 2005
My twin boom electric spad
Hi to everybody.
I'm italian and my english is bad...
I would like to show you my new spad plane.
It's made for FPV purpose.
I didn't want to build a plane whitout plan, so I decided to modify a tested spad plane.
I chose the "Buhor 25" becouse it's a trainer plane, big wing surface and simple desing.
I modified some things on it. For fpv pusher prop is better than puller so I mount motor behind fuselage.
This is not possible on original buhor fuselage so I have opted for twin boom fuselage.
Horizontal stab has same surface of original plan. Vertical stabs are twice but their surface is the same of single one in the plan.
Naturally is an electrical engine powered plane.
Some specifications:
-Wing span 40"
-Wheight 4 lbs (without fpv gear on board)
-Motor NTM Prop Drive Series 35-36A 1400Kv / 550W
-Propeller 10x6
-ESC Align 75A without bec
-Lipo Rhino 3700mAh 3S 11.1v 25C
-Aileron servos HXT 900
-Tail servos Hitech HS81
-Front wheel servo HXT 900
It's a great flyer. Take off is easy with this powerful motor. Flight is smooth and predictable. Landing? No problem even with no engine!!!
I'm very happy with this plane. I have made several test flights and now it's time to try with fpv gears on board.
Video and more pics cooming soon!!!
Creative78 is offline Find More Posts by Creative78
Old Sep 07, 2012, 06:44 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
Originally Posted by Creative78 View Post
Hi to everybody.
Your English is sure better than my Italian.
We'll be looking for the videos.
Good Luck!
Mig Man is offline Find More Posts by Mig Man
Old Sep 10, 2012, 08:12 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Very nice!
JohnsPop is offline Find More Posts by JohnsPop
Old Sep 11, 2012, 06:03 AM
Creative78's Avatar
Italy
Joined Dec 2005
Video:
Electric Twin-boom S.P.A.D. (2 min 42 sec)
More pics:
Old Sep 11, 2012, 10:34 PM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Man, that flies REALLY nice. Smooth lift off, nice flight, greased landing! Does it handle as easy as it looks? Looks like a GREAT flyer. Good job!
Old Sep 12, 2012, 02:14 AM
Creative78's Avatar
Italy
Joined Dec 2005
It very easy to fly.
I love no engine flight and landins and this spad is my first one that can landing in this way (in a good way!!!) becouse it has a good efficiency.
Its generous weight make this plane very stable but is possible to lighten it...
Fuselage isn't nice to look but I built it quickly,
A very FPV gear weight can added without flight changes.
Old Sep 12, 2012, 07:56 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
It looks great do you have plans for it?
NaterPin is offline Find More Posts by NaterPin
Old Sep 13, 2012, 06:02 AM
Creative78's Avatar
Italy
Joined Dec 2005
No plans needed...
It's Buhor 25 plane from spad:
http://spadtothebone.net/SPAD/buhor25/buhor25_1.htm
Modifications:
-No wing dihedral
-Same distance between wing and tail
-Same tails surface but horizontal stab have no sweep and tails are double
-Fuselage lenght is inverse poportion with lipo weight (for c. o. g. balance)
-Fuselage is made by 2.5mm coroplast. Section dimensions are not critical and deping of lipo dimension.
-All servos are on the wing (lower surface)
-Cut ailerons to fit propeller inside.
Old Aug 23, 2014, 05:58 AM
Creative78's Avatar
Italy
Joined Dec 2005
I try to post plans (draw by hand) and some close-up pics with details ("n30 user request).
Old Aug 23, 2014, 06:53 AM
Creative78's Avatar
Italy
Joined Dec 2005
Wing 1
ATTENTION!!!!
My measurements were made with the wing already built, to build it to refer to the image of the Buhor
Old Aug 23, 2014, 07:13 AM
Creative78's Avatar
Italy
Joined Dec 2005
close-up wing pics
Old Aug 23, 2014, 08:44 AM
Creative78's Avatar
Italy
Joined Dec 2005
Landing of my Twin-boom EP SPAD (0 min 31 sec)
Old Aug 23, 2014, 10:56 PM
n3o is offline
n3o
Find More Posts by n3o
n3o
Joined Jul 2011
Thanks!
n3o is offline Find More Posts by n3o
Build Log Maxford Spad 70 inch electric build log jasonak Electric Warbirds 3 Nov 18, 2013 08:21 PM
Discussion "Quick and dirty" electric Pod & Boom for my Chrysalis 2M wing Lacquerhead Electric Sailplanes 19 Nov 04, 2012 09:14 PM
Build Log Twin Boom albyone Vintage & Old-Timer Designs 114 Nov 04, 2012 01:36 PM
Question Twin Boom Lt599 Scratchbuilt EDFs 4 Sep 02, 2012 05:58 PM
Wtt:electric Twin Boom/prop Foam Flyer RF4CPhantom Aircraft - Electric - Airplanes (FS/W) 1 Sep 14, 2004 01:51 PM
