Old Jun 27, 2012, 01:18 PM
Riodiler1 is offline
Find More Posts by Riodiler1
United States, CA, Livermore
Joined Jan 2005
Composite Scale Electric Sailplane Question
I would like to get into a composite scale electric sailplane and the scale forum linked me to this site that sells several of them:
http://www.hobby88.com/shop/index.php?cPath=64
Just wondering if anyone has bought and flown any of these with good results and in particular, the ASW28 with the 2530mm wingspan?
Thanks!
Riodiler1 is offline Find More Posts by Riodiler1
Old Jun 27, 2012, 02:54 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
I'm thinking of getting either the ASK 21 or DG 1000 for my winter project. I already have the ST ASW 28 so I want something a little different and I would be disappointed if I got a composite ASW and it didn't perform as well as the cheap ST. I do know that the Fly Fly line are the ones offered by HobbyKing and they all seem to get glowing reviews. One thing to keep in mind is that, other than the ASK 21, the ones already built for a motor don't include flaps. So? I will either go with the ASK electric or get the DG 1000 and build in my own motor mount. If you have a big enough field the flaps aren't really needed but my field is a little tight and I need the extra glide path control on a bigger plane. My ASW can be a challenge with just "spoilerons" and I usually have to use a really low throttle to slow it down after I make my turn into final approach.
peterlngh is offline Find More Posts by peterlngh
Old Jun 28, 2012, 03:20 AM
Biggles51 is offline
Find More Posts by Biggles51
Gold Coast Australia
Joined Sep 2010
Thanks!
I have had 3 of the FlyFly ASW 28 and fly it normally a couple of times a week. A real buzz. Our crew have 2 x ASK21, 2 xCondor and a DG 1000.
There is a couple of threads going in electric and scale forums.
They are slope soarers that we use with electric motors to motor up and then
do passes. They are aerobatic....
We all think they are great value, fly great but there is a trick to setting up.
They are not thermal ships and they have to be flown with plenty of speed.
Cheers
Tony
Biggles51 is offline Find More Posts by Biggles51
Discussion Question about availability of composite powered scale sailplanes Riodiler1 Scale Sailplanes 5 Oct 04, 2012 11:50 AM
Discussion A new 2m electric sailplane olerc Dynamic Soaring 18 Jun 14, 2012 02:34 AM
Discussion CG characteristic question for an electric sailplane Riodiler1 Foamies (Kits) 1 May 03, 2012 03:52 PM
Discussion Electric conversion of scale sailplanes 2mdepp Scale Sailplanes 10 Mar 06, 2012 10:56 PM
Beginner composite electric sailplane Denny Electric Sailplanes 8 Jun 18, 2001 12:13 AM
