Old Aug 11, 2011, 08:18 AM
netdudeuk is offline
Find More Posts by netdudeuk
England
Joined Nov 2005
JR NES591s at six volts
Hi
I'd like to run my AR8000 at six volts from a pair of paralleled NIMH packs but I've read that these servos may not like that much. Please does anyone have a definitive answer ?
netdudeuk is offline Find More Posts by netdudeuk
Old Aug 11, 2011, 08:32 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Here's a discussion about that on an R/C forum in the UK:
http://www.modelflying.co.uk/forums/...gs.asp?th=8950
Miami Mike is offline Find More Posts by Miami Mike
Old Aug 11, 2011, 09:10 AM
England
Joined Nov 2005
Thanks. I spoke with the importer and he said stay with the 4.8 volt packs.
Old Aug 11, 2011, 11:58 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
Concerning using 6 volts to power NES 591 servos, the impression I get is that the situation is similar to using LiPo cells in a transmitter: People who've tried report that it works, but the manufacturers and vendors prefer to cover their butts by telling you not to do it.
But I just noticed that you're talking about using a pair of paralleled NiMh packs, which will be perfectly okay if they're both 4.8 packs. The output voltage of the paralleled packs will still be a nominal 4.8 volts and won't affect the safe operation of the servos at all. If you're under the impression that hooking a pair of 4.8 volt packs in parallel will give you 6 volts then you have it wrong.
Paralleling two 4.8 volt packs is a good way to help protect a Spektrum receiver from problems that might arise from negative spikes in voltage, if that's what you're worried about. The two packs working together will be more able to hold their voltage against load spikes than a single pack of the same size and type alone. If the extra weight in your model won't be a problem then that's a good way to go.
Old Aug 11, 2011, 12:05 PM
England
Joined Nov 2005
Originally Posted by Miami Mike View Post
The impression I get is that the situation is similar to using LiPo cells in a transmitter: People who've tried report that it works, but the manufacturers and vendors prefer to cover their butts by telling you not to do it.
Yes. The guy said that some people do report that they successfully use them on six volts but he also told me that some people send in faulty ones that were used on six faults. I say it's not worth the risk.
Old Aug 11, 2011, 12:12 PM
England
Joined Nov 2005
By the way, I just noticed that you're talking about using a pair of paralleled NiMh packs, which is perfectly okay if they're both 4.8 packs. The output voltage of the paralleled packs will still be a nominal 4.8 volts and won't affect the operation of the servos at all. I was thinking of the question you posted on the Batteries forum, where you asked about using six volts. That's an entirely different question.
I'd forgot about that thread I'll correct it.
When I first spoke with Overlander, the guy recommended the six volt pack but when I spoke with the servo importer, they said only use a 4.8 volt pack. Hence the difference in the two threads.
Agreed. Two in parallel would give the same voltage and be able to supply twice the current. Hence, a combination of more airtime and better ability to deal with higher current draw. On the other hand, two in series would give twice the voltage but at only the same current rating. Not what I need.
Sold Six Pack of JR Sport ST47 Standard Servos - Dropped to $40.00 Shipped Bajora Aircraft - General - Radio Equipment (FS/W) 3 Jul 17, 2011 05:42 PM
Question JR DS368 (not Ds368BB) on 6 volts? lenci1938e Multi Task F3X 5 Jul 06, 2011 07:32 AM
Sold JR XP7202 with 3 JR six Channel Receivers including crystals - $110 shipped Premium2000 Aircraft - General - Radio Equipment (FS/W) 0 Jun 26, 2011 10:42 AM
Sold Six unused AF connectors for sale six bucks newguy Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 21, 2011 10:11 AM
Question BEC: is six volts overkill? ZZ56 Dock Talk 1 Feb 04, 2010 05:43 PM
