Old Jul 05, 2010, 02:01 PM
shastamike is offline
Find More Posts by shastamike
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Help!
advice for Bell Head upgrade
I ordered a Bell Head upgrade for my 4#6S and the part apparently won't fit on the main rotor shaft. It's too tight. Are we supposed to use a press or vice to press the part on?
shastamike is offline Find More Posts by shastamike
Old Jul 05, 2010, 02:21 PM
celm is offline
Find More Posts by celm
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
i bought this part also,i didnt receive it yet.
shastamaike is this the one you got
http://cgi.ebay.com/walkera-4-6-S-BE...item3a5bca2e2d
keep me in the loop
celm is offline Find More Posts by celm
Old Jul 05, 2010, 02:28 PM
shastamike's Avatar
Joined Jun 2010
Yes, this is the same upgrade.
keep me in the loop
Yes, this is the same upgrade. Please let me know if you got it onto the shaft as there was no way mine was going to fit without a vice or (hammer? Yikes).
Old Jul 05, 2010, 02:53 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
have you attemepted yet again?
Old Jul 05, 2010, 03:52 PM
shastamike's Avatar
Joined Jun 2010
No...like I said, there was no way it was going to fit on the shaft.
Old Jul 05, 2010, 04:02 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That's a CB100 or CB180 head. There's no way you want to put that on a 4#6. Didn't you notice the lack of flybar weights and 45 offset? "Bell head upgrade"??? You might as well just drop a brick on your heli.
Balr14 is offline Find More Posts by Balr14
Old Jul 05, 2010, 04:15 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
thats the same head thats on this 4#6S with a bell head
http://www.walkera.com/en1/particula...n=Z14%236SBELL
whats wrong with going with a bellhead and 45deg flybar?
Old Jul 05, 2010, 05:17 PM
Dan203 is offline
Find More Posts by Dan203
Dan203's Avatar
Joined Mar 2007
I think what he's getting at is that it's not really an "upgrade". It should make the 4#6 easier to fly, if that's what you want, but it'll also make it less maneuverable compared to the stock hiller head.
I don't know why you're having so much trouble with the shaft. Did you buy an extra shaft just for this build? Or are you using the one that came with the heli? It seems unlikely, but maybe there is a slight size difference. Perhaps you should just pick up a main shaft specifically designed for that head...
http://www.chinesejade.com/walkera4_6.htm
Search for HM-4#6BE-Z-08
Dan
Dan203 is offline Find More Posts by Dan203
Old Jul 05, 2010, 09:47 PM
calvinlo is offline
Find More Posts by calvinlo
The Little Red Dot
Joined Oct 2006
I had the same problem. In the end I used a drill bit to widen the hole slightly so that it fits the shaft. Got my bell-head upgrade from chinese jade as well.
calvinlo is offline Find More Posts by calvinlo
Old Jul 05, 2010, 10:04 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
how do you like the upgrade?
Old Jul 05, 2010, 10:09 PM
calvinlo is offline
The Little Red Dot
Joined Oct 2006
At least now it flies...
But comparing it with my CB100, I do notice that it is not as agile. Sluggish is the word to describe it. Greater tendency to lose altitude when turning.
Old Jul 05, 2010, 10:17 PM
celm is offline
celm's Avatar
USA, FL, Oviedo
Joined Jun 2010
so it was better off keeping it a 90de with the flybar paddles?
Old Jul 05, 2010, 10:29 PM
calvinlo is offline
The Little Red Dot
Joined Oct 2006
As I've stated earlier, at least now it flies, and I can regularly land it with precision on very small areas. Whereas previously I just couldn't get it to hover - it just keep ramming into walls all over the place.
So IMHO, I think it is still worth it to replace the rotor head. but that's just my personal view. Hope it helps.
Old Jul 06, 2010, 12:07 AM
Dan203 is offline
Dan203's Avatar
Joined Mar 2007
For anyone else who is considering this change I would highly recommend a TechHead instead. It has a similar, although not as drastic, self stabilizing effect, howeve rit has almost instant cyclic response which make it perfect for flying in small spaces as it allows you to easily pull out of bad situations. I don't have a 4#6 bell to compare it too, but compared to my CB100 the 4#6 with TechHead is a lot more fun to fly. I just wish it was a tab bit smaller, which is why I bought a 4#3B and put a TechHead on it. However I'm having other issues with that unrelated to the TechHead which are preventing me from flying it.
Dan
Old Jul 06, 2010, 12:08 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
The 45 offset flybar design does not scale up well. It works moderately well in the CB100, but it's still a long way from learning to fly a conventional heli. The larger you scale it, the worse it gets. The 4#6S already has a 3 axis gyro. If your objective is just to have something real easy to fly, this is for you. If your objective is to learn to fly a heli, this is a step backward.
Discussion Trouble with 4#6 Bell Head Upgrade? shastamike Micro Helis 1 Jul 02, 2010 06:45 PM
Off Site Main Metal Head Set Upgrade and Tail Upgrade Set for RC Trex 450 Series Helicopters passerbyeus Aircraft - Electric - Helis (FS/W) 2 Apr 09, 2010 09:48 PM
Sold Full Metal Rotor Head upgrade head for 600 size machines SilentAngel Aircraft - Fuel - Helis (FS/W) 2 Feb 25, 2010 10:43 AM
For Sale Complete CNC Head for E-flite CP2 or Blade CP (includes Bell-Hiller upgrade) shschon Aircraft - Electric - Helis (FS/W) 4 Nov 30, 2006 07:06 AM
Wheres the thread to upgrade the blade cp head to a bell hiller head? Speedfreak Micro Helis 9 Oct 03, 2005 06:21 PM
