Old Jun 11, 2010, 06:08 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
Power System Picking
I need to pick a power system for my Pylon Racer I received.
I don't know the name. It has a 31 inch Wingspan ....
I don't want it to be horribly fast , 100-110 mph Max !
I also need a motor that what pull to many Amps , I can only fit small 1300 mah battery in this plane. I need to use around a 4 inch prop.
I would like the motor to be on the Semi cheap side.
I can fit a 28mm motor.
If you need any more information , I can get it ... except the name.
wamsy55 is offline Find More Posts by wamsy55
Old Jun 12, 2010, 03:15 AM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
That looks like a DMA Skat.
You don't say what current your batteries are good for, so it's hard to make a good suggestion. Pick something that will spin a prop about 5x5, anything over about 100W will get you going nicely.
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Jun 12, 2010, 02:07 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
My batteries can take 26 Amps ...
Old Jun 12, 2010, 04:27 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
http://www.warbirds-rc.com/Store/hett-edf3w.html with an apc 4.75x4.75 prop and 40 amp esc. You'll pull 25-30 amps and fly ~115 mph. I've had better luck with the HET motors than the Hobbycity inrunners. One of the ARC 28mm motors might be good to (at about the same price) but I don't know much about 'em.
jfinch is offline Find More Posts by jfinch
Old Jun 12, 2010, 05:36 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
Yikes thats fast !
I have used HET motors and they work perfectly. I will consider that one.
Old Jun 12, 2010, 07:26 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Originally Posted by wamsy55 View Post
Yikes thats fast !
Remember you do have a throttle stick .
Old Jun 12, 2010, 08:24 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Or if you wanna go real cheap see the power set-ups we use in our pylon racing club (~100 mph): http://sites.google.com/site/cuprapylons/ (look in the E-200 section).
Question Power system head scratcher: E-Flite PT-17 Stearman with Power 15 tdrnmartin Power Systems 18 Jan 21, 2010 02:52 PM
Help! Help in picking a good power sistem ! Bibiricat Power Systems 4 Dec 09, 2009 03:00 AM
Discussion Noobie alert!!--Help picking out a system. rcnyc78 Beginner Training Area (Aircraft-Electric) 2 Dec 28, 2005 07:31 AM
Need help picking out a 3D plane with this system passintime 3D Flying 7 Jun 13, 2004 12:14 PM
Basics of picking a power system for an e-glider? JoeR Electric Sailplanes 4 Feb 21, 2004 08:16 AM
