Old Jan 28, 2009, 08:06 PM
carl rich is offline
Find More Posts by carl rich
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
Test data Hoffman M. & Jet Scr. 1400, anyone ?
I am looking for a 1500 or + watt set up for 70mm Wemo Mini fan. I have two tested options now but am not sure if either will hold up long term. Would like to do some more testing on different motors and then post all findings at once. These two are lower kv and higher cell counts and not Hoffman or L.S.
Have not tested or been able to find any actual tests w/ hard data (volts, amps, watts, thrust, eflux) on the Hoffman motors or the Jet Screamer 1400 in a Mini fan. I've seen lots of folks bought and are planning to use, statements of expected output and talk. Somebody show me the numbers please.
4000kv and up seems like it will require tremendous amp draw on low (4s) cell count. It would be fabulous to stay under 80A w/ higher cell counts but I'm open.
Could also consider Neu 2900 or 3100kv on 5-6s,
ARC 2800, 3180kv on 5-6s
mega 16-20-2 3100kv on 5s but says 40A max
Have I left any out that aren't priced in the stratosphere?
carl rich is offline Find More Posts by carl rich
Old Jan 28, 2009, 08:27 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Go ahead Carl I'll watch We have done LOTS of testing on 3,4, and 5S in the Mini fan, HET 6904. I would love to see what you get
rvincent is offline Find More Posts by rvincent
Old Jan 28, 2009, 10:26 PM
Bajora is offline
Find More Posts by Bajora
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Um, I think he is asking somebody to post hard data on the setups he mentioned?
You know, like an Eagletree graph that shows the mentioned motors and the numbers they generated?
Bajora is offline Find More Posts by Bajora
Old Jan 28, 2009, 10:29 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
I've posted LOTS of those with the JS-1400 There is TONS of other's results as well in the JS-1400 bench test data thread too.
Old Jan 28, 2009, 11:12 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Anybody that would like hard (accurate) data on the Hoffman motors please feel free to PM me.
Pete
hole digger is offline Find More Posts by hole digger
Old Jan 30, 2009, 10:23 AM
Littlescreamers is offline
Find More Posts by Littlescreamers
Edmonds Wa. (Seattle)
Joined Nov 2003
If your just going to use DATA provided from the factories I can shoot that over. I thought you were going to run tests head to head and compare all the motors with the same fan and batts?
If this is the case we can provide you with a motor for you to abuse
Scott
Littlescreamers is offline Find More Posts by Littlescreamers
Old Jan 30, 2009, 10:51 AM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
Well, it started as me just being curious as to the performance data for the Hoffman and Little screamer motors.
NOW, it has morphed into my need to know first hand and there will be at least four motors tested in the Mini fan on a number of cell counts. The goal is to find which can handle the abuse that exceeds 1000-1600 watts.
I could use your amp draw figures on the 5s set up to determine how large my lipo packs should be. I plan to purchase new lipos specifically for this test.
Old Jan 30, 2009, 11:30 AM
Bajora is offline
KK6MQJ
Bajora's Avatar
Joined Sep 2004
I was interested in doing this exact style of comprehensive test a while ago. However, time makes us all the wiser and after observing the goings-on in a lot of motor threads around here, I now feel that this is NOT the place for such testing.
An open format where anybody/everybody can post their .02 will ultimately deteriorate into a mud slinging, name calling hullabaloo. And if you don't believe me, just poke around here a bit. Certain folks are guaranteed to show up and then it all goes downhill and it all gets ugly and it is a lose-lose for almost everybody, including the majority of the readers here, most of whom are very tired of the antics.
IMHO, one of the leading RC magazines would be a much better venue for any testing to take place.
And that is just MY .02! (See, like I said, EVERYBODY will just have to add a couple of pennies worth! )
Old Jan 31, 2009, 06:36 AM
tungym is offline
Find More Posts by tungym
tungym's Avatar
Planet Earth
Joined Jul 2005
I just test a Hoffman with a 5 blade 70mm EDF (Not WeMotec). @4s (4s2p 2200mAh)it takes 100A !!! I put it on my Rafale and the performance is stunning!!! Since that is a short flight test and I will have further benchtest for other fan as well.
For a 4300kv+ motor, I believe it can perform well even at 3s, in order to calm down the current! My T plug melt after some full throttle burst !
I wonder why the stator mount and end bell is may of plastic (certainly good one) ? This gives me a surprise when I receive the motor!
tungym is offline Find More Posts by tungym
Old Jan 31, 2009, 11:43 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Waiting for my Wild Beast Carl. Will be next weekend earliest before I get a flight in with EagleTree data.
DominicM is offline Find More Posts by DominicM
Old Jan 31, 2009, 12:27 PM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
I'll look forward to your full report.
Old Feb 01, 2009, 08:26 AM
supershuey is offline
Find More Posts by supershuey
damn gravity again
supershuey's Avatar
trowbridge, Great Britain (UK)
Joined Jan 2004
hi all
well i got the arc and the wild beast is ordered now i just need a uk
seller that has the ls1400 in stock i got the het 3 blade and 4 blade
and the wemo too test,
eagle tree is all ordered just waiting on my next payday
ill be adding test data when all is arrived all tests will be done with same
batts and esc,fans
Dylan
supershuey is offline Find More Posts by supershuey
Old Feb 01, 2009, 10:23 AM
EDF Nut
carl rich's Avatar
Cincinnati
Joined Jan 2006
At this point I have all motors but Beast in the mail and on their way. ARC, Medusa and LS1400 w/ Mini.
Dylan, we could kill two birds w/ one stone if you had another 70mm fan to test on. Would you happen to have the HET or the WM400 for testing? Doesn't hurt for us both to test same motors in the same fan but we'd get more info if there was some variation. It's fine either way. The more testing the better!
Old Feb 01, 2009, 10:31 AM
damn gravity again
supershuey's Avatar
Joined Jan 2004
hi
yes i have the het and mini fan ill see if i can get all the 70mm fans
im looking forward too testing the ds copy het dropped as i have a few of them and i love them only the rotors though as the motor mount was slightly
not central,
so ill be looking forward too this testing got some 4s 5000 30c coming too
5s on the ls1400 im very intrested in
Dylan
Joined Nov 2003
So what your saying is that the one hold-out will not send a motor for testing??
Bummer
Scott
IPS II test data jamie516 Parkflyers 3 Feb 17, 2002 05:31 AM
It's not as good as DNA's but here is some motor test data on qc830's Spaulding Parkflyers 5 Feb 04, 2002 03:39 PM
Test Data on Sanyo RC3000HV pgleesonuk Electric Plane Talk 1 Jan 29, 2002 11:56 AM
Updated Mag. Mayhem test data slowflyer Foamies (Kits) 11 Oct 21, 2001 07:47 AM
450 turbo vs Mag mayhem test data slowflyer Foamies (Kits) 8 Aug 06, 2001 12:51 AM
