Old Feb 14, 2007, 12:46 PM
Plat3au is offline
Find More Posts by Plat3au
Dallas, TX
Joined May 2006
Cool
Screaming 1000W Zagi
Ok, here’s the current power setup:
Zagi XS Pro Kit 48” (chopped down to 40”)
Mega 16/15/3 w/ Heat Sink
E-Flite 40 amp ESC w/ BEC
Kokam 3s1p 2000 mAh 15c LiPo (+1 spare)
5.25 X 4.75 APC Prop
Specs:
Flying Weight: 25 oz
Current Draw: ~30 amps
Results:
Top Speed: 80-90 MPH
Problem:
It takes too much time to build up that speed and the vertical climb rate is poor. So basically, I want more power.
Now I've talked to several guys at the local hobby shop and they all say different things. One said I'm using the wrong prop but I've metered a dozen different props (including the one he suggested - APC 5x5) and the 5.25 X 4.75 gets me the most bang without exceeding the 30 amp limit that the motor and battery have. Another guy said that I need to buy the Mega 16/25/3 motor w/ 7x7 APC prop, which I'm sure would throw off the cg on my zagi but no big deal if it would do the trick. And yet another guy recommended that I toss the E-Flite 40 amp ESC and get the Phoenix 45 or 60, then run my two lipos in series making a 6s1p 2000 mAh 15c LiPo. But I'm not sure if that would blow up my zagi or not. Sounds a bit hot.
Has anyone tried any of these suggestions or can you think of other ways to get this baby doing unlimitted vertical?
Any help would be greatly appreciated.
~Brad
Plat3au is offline Find More Posts by Plat3au
Old Feb 14, 2007, 03:47 PM
soarus_1999 is offline
Find More Posts by soarus_1999
soarus_1999's Avatar
Saint Paul, Minnesota
Joined Jul 2006
i have a Zagi Tazz...i think its the same thing. and this is the setup i have:
Zagi brushless motor (one that comes with the Tazz)
Caste Creations Phoenix 45 amp brushless speed control
HS-81 servos (2 of them)
3S1P 20C 2500mah lipoly pack
The props i use are the carbon zagi props...not sure what the dimension is, i can check tonite when im home to see.
I pull between 35-40 amps i think when we did the wattmeter check, its been almost a full flying season since i checked last.
Ive also looked at upgrading to the smaller prop.
I havent clocked it in a dive or high speed pass but id say its in the 70-80mph range, might be more in a dive or downwind pass, i should check! . And it can pull vertical for quite a distance, not unlimited but id lose visibility of it before it would stall. So that works for me hehe
-David
soarus_1999 is offline Find More Posts by soarus_1999
Old Feb 14, 2007, 04:54 PM
navyguy is offline
Find More Posts by navyguy
What's a custom title?
Tracy, CA
Joined Feb 2006
stock tazz setup is an astro 020 cc 25 1700 or 1800 nimh and 5x5 carbon prop. They say with a 3s2p 4200mah lipo, you should do 100+ easy
navyguy is offline Find More Posts by navyguy
Old Feb 15, 2007, 09:53 PM
swattley is offline
Find More Posts by swattley
Joined Dec 2004
i have the mega 16/15/4 with a thunderpower 3s2p 4200ma lipo, the stock 5x5 zagi prop was ok but i now have a APC 6x4. the battery makes a huge difference. my wing is a zagi 60 and it has lots of power and i get 15 min flight times only taking 80 percent out of the pack.
swattley is offline Find More Posts by swattley
Old Feb 15, 2007, 10:03 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
I run a Mega 16/15/3
Apc 5.1x4.5
Jedi Opt 90 esc
5s TP Extreme 2070 lipo.
Seperate Rx. battery.
I get 900-960 watts and draw 62-65 amps.
The only thing I worry about is if the prop can take it!
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Feb 16, 2007, 12:10 AM
Howard Hughes is offline
Find More Posts by Howard Hughes
Howard Hughes's Avatar
Joined Aug 2006
Parallel the 2 packs and run an apc 5.5 x 4.5 , this set up will over amp on the test bench. in the air the amps load will drop, and wings have good cooling for the motor. the heat sink help also. in any case, the motor should come back cool. this has alot more thrust. but you must parallel the packs you need more discarge. on the bench you'll pull about 38 amps.
Howard Hughes is offline Find More Posts by Howard Hughes
Old Feb 16, 2007, 02:08 AM
Ebolavoodoo is offline
Find More Posts by Ebolavoodoo
Ebolavoodoo's Avatar
United States, CA, El Cerrito
Joined Jan 2007
I looked up the cost of the Mega motors and whoah they are not cheap! Sorry to get off subject but can anyone point me in the right direction of a motor out there in the 2000-3000Kv range to push a zagi that ISN'T expensive? Light, fast, and cheap...
Ebolavoodoo is offline Find More Posts by Ebolavoodoo
Old Feb 16, 2007, 06:29 AM
turn, turn, turn.
Joined Oct 2005
Megas are cheap!
You DO want it to last, right?
It's hard to find a more affordable, reliable, and powerful motor to push a Zagi.
Old Feb 16, 2007, 06:32 AM
turn, turn, turn.
Joined Oct 2005
38 amps? I'd be surprised.
I'd say half again as much...at least.
Old Feb 16, 2007, 06:54 AM
Joined Jan 2007
I guess Megas aren't too bad a price
MEGA ACn 16/15/3 - Speed 480 size Brushless 3T $84.50
MMC2800 LittleScreamers 2800 Kv Brushless $ 48.70
Is this littlescreamer comparable to the 16/15/3 ?
Still learning about motors/props/batteries
Old Feb 16, 2007, 06:59 AM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
warbirds-rc.com HET 4 w the same as a mega but 1/2 the price , ck
klique is offline Find More Posts by klique
Old Feb 16, 2007, 07:04 AM
Joined Jan 2007
That price is more like it for my taste. As I get more electric experience, I can get fancy with the expensive motors. Thanks for link klique
Old Feb 16, 2007, 07:13 AM
turn, turn, turn.
Joined Oct 2005
How can this be!?!
The same at half the price?
Not.
I suspect foul play here.
Old Feb 16, 2007, 07:58 AM
Plat3au is offline
Dallas, TX
Joined May 2006
Apc 5.1x4.5
Jedi Opt 90 esc
Wow! The Mega 16/15/3 can handle 65 amps? I thought it's max was 30 amps. Have you clocked this setup?
Old Feb 16, 2007, 09:20 AM
Challenger 413 is online now
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
You can buy factory repaired 16/15/3 at about half price from Mega Motors directly.
I broke the wire at back plate on a 3 yr. old one, sent it in and asked for a repaired motor. I think it cost about $55.00, and it looks like it did when I first bought it from another dealer. I haven't ran it yet as I bought a 1107/2.5Y Neu Motor for more power in my application. Just another option for y'all.
I was running that 3 yr. old on 4S1P 2100, mini box at 6 to 1 ratio, 15X7 APC E prop at 35 amps, with heat sink, but it ran probably 75 flights before I nosed in the plane and broke the wire. The Mega's are so tough...
Challenger413
Challenger 413 is online now Find More Posts by Challenger 413
