Old Apr 29, 2002, 08:53 AM
Skiboy is offline
Find More Posts by Skiboy
Trondheim, Norway
Joined Apr 2002
Question
Hitec feather reciver
I have build my self a Terminator HLG and I need a new reciver to put in it. I have been in contact with my local hobby store and they did NOT recomend me to use the Hitec feather reciver, since it's operating distance was only 100-200 meters. Is this correct? If it is correct, is it enough? Do you have any other recomendations for a reciver to put inside my HLG.
Thanks in advance
Andre
Skiboy is offline Find More Posts by Skiboy
Old Apr 29, 2002, 10:51 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
I think Hitec rate it up to 500ft which is about what you say. However, these ratings are extremely conservative and you should easily get a lot more in a glider where there is no motor interference to contend with. For a hand launch glider I think you should be OK.
DaveSawers is offline Find More Posts by DaveSawers
Old Apr 29, 2002, 12:09 PM
Skiboy is offline
Trondheim, Norway
Joined Apr 2002
It sounds like you are 99% sure, but the last 1% what kind of receiver would you go for then. Just so I have an option.
Thanks again
Old Apr 29, 2002, 12:13 PM
Doc Data is offline
Find More Posts by Doc Data
United States, FL, Starke
Joined Apr 2002
Use a Hitec 555, remove the case and shrinkwrap some battery pack wrap around it. It fits great, weighs next nothing and there won't be a range problem. We had a guy in the club try one out for a while... he sent it back... not enough range.
dd.
Doc Data is offline Find More Posts by Doc Data
Old Apr 29, 2002, 12:52 PM
Viffer is offline
Find More Posts by Viffer
Canada
Joined Apr 2002
I wouldn't recommend the Feather in a glider. I use the feather in my park flyers which are flown well within the 600ft range. But for my gliders, I'd go with the 555 since quite often they will reach 1000 ft ranges and more if chasing thermals. I wouldn't want to chance it with a glider - kinda hard to bring them back when you're out of range.
I just picked up a Dymond Micro 4 channel which is almost the same size as the Feather but with a 1500 ft range. I haven't had a chance to try it out as yet but which will enventually go into a 1.5M HLG.
Viffer is offline Find More Posts by Viffer
Old Apr 29, 2002, 01:00 PM
Joined Oct 1999
I would agree with the other comments. There are several small, (alomost) full range receivers out there. Have a look at the Multiplex Pico and the Ceto range.
Old Apr 29, 2002, 04:42 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
My experience of the Feather indoors was bad - glitches at 60 ft range! I would go with some of the other options suggested.
Mike Smart
Mike Smart is offline Find More Posts by Mike Smart
Old Apr 30, 2002, 01:17 AM
Skiboy is offline
Trondheim, Norway
Joined Apr 2002
thanks
Thank you guys for all the replys.
It sounds like I will go for a 555 and then shrink wrap it. In this case I also have the oppertunity to use it in another plane later.
(I will check out Multiplex Pico and the Ceto range)
Thanks again
Old May 03, 2002, 10:04 PM
rlt55 is offline
Find More Posts by rlt55
Senior Moment
rlt55's Avatar
Woburn, MA, USA
Joined Jul 2001
GWS
Check out the GWS R-6N/H
I'm using them on my Elster 1.5 and FMA Razor.
I fly where there are microwave dish antennas (plus UHF com, cell and pager transmitters) so I use metal foil around the cover.
They work very well and don't cost a lot.
I've never had RFI from other RC pilots/Tx channels.
Rich<>
rlt55 is offline Find More Posts by rlt55
Old May 05, 2002, 12:24 AM
Dauntae is offline
Find More Posts by Dauntae
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
Take a look at the FMA Extreme 5 Sub Micro Receiver, great range and more compact than a 555
Dauntae
Dauntae is offline Find More Posts by Dauntae
Old May 05, 2002, 09:07 AM
rlt55 is offline
Senior Moment
rlt55's Avatar
Woburn, MA, USA
Joined Jul 2001
I like my Extreme 5 better than the 555. It does not move the servos around during loss-of-signal.
If you forget and turn off your transmitter 1st, the servos just sit there.
The 555 will start buzzing around (due to noise)..
Rich<>
Help! HITEC feather reciver studers jeffhines Parkflyers 6 Jan 19, 2002 05:10 PM
glitching or strange problems with a Hitec Feather receiver?? KOMET 44 Power Systems 3 Jul 28, 2001 12:09 AM
Hitec Feather antenna question Karl Parkflyers 3 Jun 24, 2001 01:11 AM
gws receiver vs. hitec feather? thrmaln Parkflyers 27 Jun 08, 2001 02:09 AM
Hitec Feather Antenna length???? Bleriot Parkflyers 2 May 07, 2001 09:42 PM
