Old Jun 27, 2015, 05:37 PM
anewton is offline
Find More Posts by anewton
Whoa……it flies
anewton's Avatar
Australia, VIC, Geelong
Joined Feb 2007
Mini-HowTo
Hot Wire airfoils
I have just recently tackled this method for foam wing builds and it's working well.
Previous wings were tape-covered and folded depron which have been excellent.
Here's my beginners perspective on hot wire cutting.
Hot wire airfoils (6 min 8 sec)
anewton is offline Find More Posts by anewton
Old Jun 27, 2015, 07:01 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Good one Andrew.
You don't need to burn the nylon off the leader wire. If you run a blade along the wire it'll cut a long shaving and then you can easily peel the remaining coating.
Is that foam from Bunnings?
Whiskers is online now Find More Posts by Whiskers
Old Jun 27, 2015, 07:13 PM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Thanks for that great tip Whiskers. Yes the foam is from Bunnings in Geelong. Might be a recent addition because I have never seen it there before.
Old Jun 30, 2015, 10:38 AM
mwrzesinski is offline
Find More Posts by mwrzesinski
Trabado por las importaciones
mwrzesinski's Avatar
Argentina, CABA, CF
Joined Jan 2015
https://www.youtube.com/watch?v=JIRz...ature=youtu.be
good video.
what do you use to laminate the wings? can you paint over the laminate?
mwrzesinski is offline Find More Posts by mwrzesinski
Old Jun 30, 2015, 03:23 PM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
75 micron document laminate
EZload laminate - http://www.neopostonline.com.au/lami...load-roll-film
I have not tried painting it
Old Yesterday, 03:18 AM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Here's another video on spar channel forming
1. Hot wire slot for 6 x 1mm flat spar
2. Hot wire circular channel for arrow shaft spar
3. Drill jig for drilled circular channel
Spar hole drilling jig (3 min 15 sec)
Old Yesterday, 08:27 AM
rcguy1958 is offline
Find More Posts by rcguy1958
USA, NY, Poughkeepsie
Joined Mar 2010
Excellent work on the cutting and the videos.I have a few tips you may find helpful.
First the wire. The correct wire to use is very difficult to find locally even here in the states, but thankfully there is a fantastic on line distributor http://www.jacobs-online.biz/rene_wire.htm. You won't need to purchase large quantities of this wire as it lasts a really long time ( 30 sets of wing halves and numerous test cuts on the same wire and still going strong). You'll see that it heats up faster and retains it's temperature longer than the wire you're currently using, that equals faster cuts and less distortion.
Second, if you're serious about doing a lot of cutting, a transformer setup is the way to go. You'll get constant volts and amps, making smoother cuts, and be able to cut away to your hearts content with out having to stop to recharge. Less chance of damaging your batteries plus the added ability to control your voltage and amps and keep those settings constant. Jacobs is an excellent resource for everything you'll need to build your own ( just a transformer and dimmer switch in a box, instrutions available @ jacobs. )
Third, it looks like a lot of work and materials went into making that bow, but your not keeping enough tension on your cutting wire( hence the wire lag and the need to move very slowly (( wire lag is the reason for the weird trailing edge and difficulty going around the leading edge)) ). It's actually a combination of your power supply, the type of wire and the design of the bow that's giving you this. I've attached a couple of pics of an easy to assemble bow that when used with good single strand wire will keep good tension and lessen the amount of wire lag. Super simple design ( copied from http://www.acpsales.com/Hot-Wire-Bows.html) I used pine for the back bone with holes for the music wire drilled at 20 degrees outward, and 1/4" music wire. Funny thing about doing this, the electrical current only runs between the alligator clips, any wire ( or the steel legs) outside of the clips does not get hot or seem to carry any voltage, but as a precuation , I've taken to covering the steel legs of my bow in shrink tubing just to be safe.
I'm not overly technical when I cut( don't measure volts or amps, I know the speed I want to cut at and just turn the dimmer up or down until I get the speed I want to work at, put a piece of masking tape on the switch plate to make a mark so I can repeat the setting for that particular cut).
Hope my suggestions are helpful, fantastic work so far. That bow design I recommended is infinitely adjustable, I just made a smaller one with a handle off the back ( like a paint brush) for cutting fuselage " slices" similar to the designs by Tetris here on rcgroups.
rcguy1958 is offline Find More Posts by rcguy1958
Old Yesterday, 11:10 AM
mmattock is online now
Find More Posts by mmattock
Canada, AB, Airdrie
Joined Oct 2014
Before buying a step down transformer, have a look at your battery charger. Quite a few of them have a mode for hotwire cutting where they supply a constant voltage/current. My Reaktor 300W charger does this with control over both voltage and current supplied along with a timer function. All of the various i-charger clones and similar designs should have this as well.
Mark
mmattock is online now Find More Posts by mmattock
Old Yesterday, 03:07 PM
Joined Mar 2010
I used my i-charger at first...but you'll notice that it is difficult to get the proper amps supplied at the desired voltage. Even after changing the settings, the charger will over ride the input and lower the voltage based on the amperage picked. My transformer set up cost me approx. $60.00 and makes much better cuts than when controlled with my charger. Also, the time to get the wire to temperature is much longer and makes gravity cutting less reliable.
Old Yesterday, 05:04 PM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Excellent links and suggestions, many thanks.
My simple battery operated setup works well enough for the moment. I have a brushed ESC and servo tester on the way to allow voltage control.
Discussion What airfoil to use on Gentle Lady hot wire cut replacement wing? andrewwl Sailplane Talk 30 Aug 21, 2014 06:34 AM
Discussion Hot wire a little too hot Triggerhappy Hand Launch 4 Aug 12, 2014 07:03 PM
Discussion Hot Wired Airfoil selction for aerobat (Swinger) Hexosex Slope 11 Jul 27, 2009 07:08 PM
Rant This is my best hot wire airfoil cut yet dougmontgomery Hand Launch 53 Mar 31, 2007 12:51 AM
Discussion Hot wire cutting - or however you make an airfoil The L Foamies (Scratchbuilt) 19 Oct 27, 2006 10:28 PM
