Old Mar 08, 2014, 05:14 AM
tinkerer2011 is offline
Find More Posts by tinkerer2011
Joined Mar 2014
help with twister blackhawk please :)
Hi,
I have cleverly taken a perfectly servicable Twister blackhawk and stuffed it up by trying to change the receiver.
It had the planet R6M receiver and i wanted to use my DX8 with it, so I changed the receiver to an AR6115e
Now the rotors won't rotate. when I move the aileron or elevator controls the servos moving the swash plate move, but selecting power or rudder won't make the rotors move.
The rudder and throttle connectors are connected to the rudder and throttle channels on the receiver and the 3 in 1 is connected to the motors. the 3 in 1 led glows red - not sure if that means anything.
I should add that this copter has the planet 3 in 1 control unit.
if anyone can help with the required settings for the dx8 and any tips on what i might have done wrong with the receiver i would be really grateful.
thanks
tinkerer2011 is offline Find More Posts by tinkerer2011
Old Mar 08, 2014, 10:27 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Spektrum channels don't map the same. You are going to have to find the right ones by trial and error.
Balr14 is offline Find More Posts by Balr14
Help! Mcpx brushless conversion PLEAS HELP ME Newbie77 Beginner Training Area (Heli-Electric) 3 Nov 19, 2013 05:35 AM
Help! Futaba T7C refuses to work with throttle trim. Plea for help :) bigo66 Radios 2 Sep 01, 2011 01:23 AM
Discussion Plea for help with HS-85MG gears... wylchyl Hitec/Multiplex USA 11 Sep 04, 2008 10:01 AM
Discussion Pleas Help me with walkera 36 WK-0701 Tx kaushiksad Simulators 1 Dec 03, 2007 06:26 PM
Help With Charging Li-Po's With Triton Charger Pleas? Synthetic Batteries and Chargers 13 Dec 17, 2004 08:08 PM
