Old Jun 15, 2013, 03:40 AM
Radar1 is offline
Find More Posts by Radar1
United Kingdom, Tenterden
Joined Jun 2013
What to Power up?
Hi all, have Logger V4 with Guardian Stab, OSD Pro and GPS Expander. I have flown my model ( with Stab gain dis abled) and all is good. So now have enabled Stab and wondering does the camera and osd display need to be powered for correct operation? Worried that that configuration may cause a problem. Am approaching the set up cautiously Sure some one has the answer. Thanks.
Radar1 is offline Find More Posts by Radar1
Old Jun 16, 2013, 09:01 AM
garris2 is offline
Find More Posts by garris2
Melbourne, Australia
Hi Radar, your OSD gets its power from your eLogger.
You need to provide power to you camera/ video transmitter separately.
Watch out for ground loops.
The good thing about the OSD is the the Video in/out and Audio in/out connections are "pass-through".
That means you can set up you video and audio wiring using a 3 wire servo cable (video, +Pos, -Neg) as if the OSD is not present, then when you've got it setup, cut the 3 wire cable in one place and put 2 male servo plugs on and plug them into the OSD.
Do the same for the audio if you're going to use it.
Geoff
garris2 is offline Find More Posts by garris2
Sold HURC Power UP 25 Speed and Sky Power 60A ESC 40.00 Shipped campbellj Aircraft - Electric - Power Systems (FS/W) 1 Mar 30, 2013 08:53 AM
what is the most powerful motor set up for 550mm Logo10? GTOVR4 Electric Heli Talk 10 Nov 11, 2004 10:47 AM
3DX - all up weight and power set-up... what's yours? CactusJackSlade 3D Flying 15 Mar 25, 2004 11:18 PM
What is the Lightest Cell With the Most Power? Up to 15A draw. wannabe Parkflyers 8 Nov 26, 2003 01:38 PM
What is the ultimate power set up for my Funtana ? Ali Sport Planes 38 Oct 26, 2003 08:32 AM
