Old Jan 27, 2013, 08:40 PM
SkyRaptor is offline
Find More Posts by SkyRaptor
Brazil, São Paulo, Campinas
Joined Apr 2010
"Cell Cnt Changed" error when charging an AGM Lead battery
Hi guys,
I'm facing an weird issue when charging 2 AGMs 75Ah batteries tied in parallel.. (2 Packs, 18A each, 36A total)
The preset has a config called "Verified Cells Time"..
When this times expires, the charger stop and issue this error:
"Cell Cnt Changed"
I tried to change this time do 1min and to 15 min.. same issue.. after that time, the error shows up.
Before starting the charge, the PL8 ask to confirm if I am charging a 6S battery..
I have tried replacing the power supply, but same issue with 12V or 24V PS...
Attached there are two logs (with 1min and 15 min) and the Preset (all renamed to .txt extension)
Any clues??
Alex.
SkyRaptor is offline Find More Posts by SkyRaptor
Old Jan 29, 2013, 04:21 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by SkyRaptor View Post
Hi guys,
"Cell Cnt Changed"
Any clues??
Alex.
Hi:
I went to the design engineer with your inquiry. He did something really special for you. Attached, you will find a new AGM preset that has these altered configuration details:
I raised the cell detect voltage up to 2.6V and set it to fixed 6 cell count
If you download and unzip the preset to a folder in your computer, then you can import it into the CCS on an empty preset (or overwrite one).
Let me know if you have any questions, and let me know how you make out with it.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Jan 31, 2013, 05:20 AM
Joined Apr 2010
Hi Tim,
I tested this new profile and so far so good.. It was a complete charge with no issue at all.
Thanks again!!
Alex.
Old Jan 31, 2013, 05:46 PM
Tim Marks's Avatar
Joined Mar 2008
Hi Tim,
Thanks again!!
Alex.
Hi Alex:
Hey, that's Great! You're welcome!
Tim Marks
Discussion error "Wrong cell count" on 12V lead battery jlp3883 FMA Direct 3 Jul 16, 2013 02:44 PM
Question If you wish to charge the included battery from an AC power source, you will need the mikeydrc United Kingdom 5 Jan 28, 2013 04:52 PM
Discussion New Bright RC car Li-Ion battery 4 cell, how to charge with AC6??? shahram72 Batteries and Chargers 7 Jan 08, 2013 09:53 AM
Discussion E-Flite Battery Charge Error on Cell 1 jbobchordie Beginner Training Area (Heli-Electric) 2 Jul 14, 2009 12:19 PM
Discussion DN Lipo Charger only shows 2 cells when charging 3 cell battery tooconceited Batteries and Chargers 11 Mar 10, 2008 09:10 PM
