Old Feb 01, 2012, 02:41 PM
bobmic is online now
Find More Posts by bobmic
Bobmic
Canada, ON, Vaughan
Joined Jun 2011
Question
How to connect a Brushless RPM and an Optical RPM at the same time
Can anyone explain how to connect 2 RPM sensors at the same time on eLogger4?
I have a brushless and an optical sensor that I would like to connect and in the manual for the brushless rpm sensor it is mentioned that 4 RPM sensors can be connected but there is no description on how to do that anywhere.
Thank you
bobmic is online now Find More Posts by bobmic
Old Feb 01, 2012, 05:46 PM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Thank you
Up to 4 RPM sensors can be connected to the "Pro Data Recorder", not the eLogger.
The Brushless sensor can also be used as a secondary RPM sensor with your Recorder. Up to 4 RPMs can be
measured in this way (with the Pro Recorder). To use the Brushless sensor as a Secondary sensor, please see
your Seagull or Recorder instruction manual for instructions on modifying it.
I don't know if the eLogger is capable of more than one RPM sensor.
Best of Luck,
Rob
camship is offline Find More Posts by camship
Question how to create 3 video clips in one frame playing at the same time? kryptoknight FPV Talk 3 Sep 15, 2011 12:23 PM
Poll Flying multiple planes (LRS's, other tx systems) at the same time ecampos FPV Aircraft 5 Jun 12, 2011 11:40 AM
Discussion Improve education and save some taxpayer money at the same time... logan5 Life, The Universe, and Politics 7 Apr 26, 2011 11:22 AM
Question How do I charge Rx packs and Tx at the same time with only a 12V supply? gdh240 Australia 19 Apr 14, 2011 07:22 AM
