Old Oct 05, 2010, 11:12 PM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
WALKERA 2801 TX, SWASHMIX(SWAATS) question
Hi guys,
I've built 2 helicopters, both the same setup, with the same servos, and gyro etc, same RX 2801E, all the settings are the same the only thing that I have to change is the swashmix. Why isn't the SWAATS settings the same? Why can't I use the same settings. Each one has different SWAATS settings.
Swashmix Settings for each heli
Heli 1
ELEV 50%
AILE - 50%
PIT 50%
Heli 2
ELEV - 50%
AILE 50%
PIT - 50%
Thank you
pitchp
P.S. I thought I'd ask here aswell since there might be users here that might know
pitchp is offline Find More Posts by pitchp
Old Oct 06, 2010, 08:36 AM
blimppilot@ph is offline
Find More Posts by blimppilot@ph
SirEdward
blimppilot@ph's Avatar
Philippines, NCR, Pateros
Joined Apr 2004
Its because of the servos direction of travel. remember that in CCPM setup we first setup up the servos to move up and down collectively, we then adjust proper direction in SWASHMIX by changing the sign either + or -.
do you have different servos brand among those two choppers?
blimppilot@ph is offline Find More Posts by blimppilot@ph
Old Oct 06, 2010, 08:55 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
The servos direction of travel should be the same
Here's my specs http://www.rcgroups.com/forums/showt...1316231&page=3
Old Oct 06, 2010, 07:48 PM
Ampdraw is offline
Find More Posts by Ampdraw
Australia...we live inverted.
Joined May 2008
Check your channel reverse settings for all servos are the same and the servos (left and right ie pitch and aile) are in the same channels of their associated rx's.
Also servos orientated the same way..ie horn toward the front as opposed to the rear of the heli.
Amp
Ampdraw is offline Find More Posts by Ampdraw
Old Oct 06, 2010, 08:58 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
done. checked. the same. i don't understand. i've pulled apart my 4g3 and put it back together, and it's the same swashmixes as my other one. Could it be my RXs wired incorrectly?? If everything else is the same, the swashmixes should be the same, is that right Amp??
Old Oct 06, 2010, 10:51 PM
Ampdraw is offline
Joined May 2008
Absolutely everything the same...yep swash mix neg and postitive values will be the same with maybe slight variation in the numerical value due to link length, servo throw etc.
Some servos actually move the opposite way to "standard" when they receive pulse. They may have revised the servo between your purchases.
Also just plugging the pitch servo and aile servo opposite vastly changes the channnel reverse and swash mix.
Amp
Old Oct 07, 2010, 02:03 AM
SirEdward
Joined Apr 2004
Amp
+1 on this, if you really want to have identical SWASHMIX values on both helis you should setup your servos so that their "standard" movement is the same from gound up.
Old Oct 07, 2010, 02:22 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
Amp
" They may have revised the servo between your purchases."
ohh crap, are you serious. they are the same brand, same model, different color casing. You hit the nail again. Cheers Amp!
P.S What did they change besides the casing? one is blue(older version) one is black(new version). The distance of travel is still the same, just the direction is different.. Turnigy could atleast change the label to "Turnigy 1440A V.2". Anyways, Thanks guys!
Alert Walkera 2609 RX gyro-less: 2.25gm 6 Ch 2.4GHz receiver for walkera TX 2801 robZulu Scratchbuilt Indoor and Micro Models 9 Nov 30, 2013 06:28 PM
Discussion Walkera WK-2801 TX - how to set up and use with the Walkera 2.4 ghz heli range Vimd Micro Helis 930 Jul 19, 2012 01:39 PM
Discussion Walkera 2801 TX, Swashmix(SWAATS) question pitchp Micro Helis 1 Oct 07, 2010 11:55 PM
Sold Walkera 2801 Pro TX, $100 MiniChopper4Me Aircraft - General - Radio Equipment (FS/W) 3 Aug 10, 2010 02:50 PM
For Sale Walkera 4g6, 4#6, 2801 Pro Tx, 2402 Tx kcalvano Aircraft - Electric - Helis (FS/W) 6 Jul 06, 2010 08:03 PM
