Old Mar 02, 2010, 09:28 PM
nano cup is offline
Find More Posts by nano cup
Bryson Ca.
Joined Feb 2010
Proper Tire Glueing Method???
Ok I thought I knew how to glue tires to wheels.Cant keep my GRP tires on my TT wheels. I've spun the wheels on my lathe to remove the powder coat/anodizing,Cleaned wheel and tire,tried CA and a thicker tire glue. Maybe my bikes are to fast???HaHa Thanks N/C
nano cup is offline Find More Posts by nano cup
Old Mar 02, 2010, 09:39 PM
Torrance is offline
Find More Posts by Torrance
Torrance's Avatar
Joined May 2009
there was a thread on this a while back.
http://www.rcgroups.com/forums/showthread.php?t=1104968
from my experience it seems that tires stick better to an anodized or powder coated surface than bare aluminum.
edit: i just looked through that thread and it's kinda useless because we just talked about beadlocks and inner tubes. although i remember seeing on another thread that some type of Loctite compound works great. but i can't remember which thread it is.
Torrance is offline Find More Posts by Torrance
Old Mar 02, 2010, 09:52 PM
Roofas is offline
Find More Posts by Roofas
Who needs 4 wheels..
Roofas's Avatar
Australia, VIC, Menzies Creek
Joined Aug 2009
I use Loctite 480 for gluing my tyres to TT rims.
Roofas is offline Find More Posts by Roofas
Old Mar 03, 2010, 12:00 AM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
I prep tire and rim with denatured alcohol or at least 91% isopropyl and use Shoe Goo inside where the bead sits in the groove, then a fillet around the outside where the sidewall meets the rim. It's a two-night process to let it cure, but they hold for months before I have to re-do the fillet.
Guidoracer is offline Find More Posts by Guidoracer
Old Mar 03, 2010, 01:13 AM
ehirobo is offline
Find More Posts by ehirobo
Hong Kong
Joined Nov 2008
x2. No need to take the coating off. Just clean the rims use loctite 480.
ehirobo is offline Find More Posts by ehirobo
Old Mar 03, 2010, 01:37 AM
edi.winter is offline
Find More Posts by edi.winter
edi.winter's Avatar
Tirol
Joined Jul 2009
Loctite 480.....
edi.winter is offline Find More Posts by edi.winter
Old Mar 04, 2010, 04:38 PM
Dez82 is offline
Find More Posts by Dez82
Dez82's Avatar
Warwick - UK
Joined Feb 2006
Don't forget the tyre has release agent on it to get the rubber out of the mould! I clean the whel rims and tyre beads themselves with lighter fluid, fit the tyre and insert then just run thin CA into the bead area and clamp down with a rubber band, never lost a tyre yet!
Dez82 is offline Find More Posts by Dez82
Discussion checking screws, proper method? xbted Electric Heli Talk 3 Jul 24, 2009 01:27 AM
Discussion No Proper Method for LiPo Disposal dlmcmichael Batteries and Chargers 4 May 08, 2007 02:49 PM
Discussion tire glueing trick Mentalmadness Motorcycles 3 Apr 02, 2007 02:06 PM
Proper method of lipo disposal? lensrc Batteries and Chargers 4 Dec 31, 2004 07:56 AM
Proper Method To Use Astro Whatt Meter? TiberianMaster Power Systems 4 Nov 05, 2003 09:26 AM
