Old Apr 23, 2010, 11:53 AM
HoverTim is offline
Find More Posts by HoverTim
HoverTim's Avatar
Joined Mar 2007
Griffon 2000
I was lucky enough to go to the factory and saw the craft i am doing been built this got me interested i then contacted the owners of teh craft and got a load of pics i then went back to griffon enquiring about plans then i had to go back to the owners of the crat to get permission to let me have the plans then back to griffon to get a copy so it can be done but its looking fro the craft that interests you
HoverTim is offline Find More Posts by HoverTim
Old Apr 23, 2010, 11:56 AM
HoverTim is offline
HoverTim's Avatar
Joined Mar 2007
i have hada look through the stuff i have and i have found a small PDF plans no good to work from but it will give you an idea please email me at tim.g.stevenson@btinternet.com and i will send it to you
Old Jun 07, 2014, 01:59 PM
Burakko is offline
Find More Posts by Burakko
Burakko's Avatar
Joined Aug 2012
me to burakko@tlen.pl
Burakko is offline Find More Posts by Burakko
Old Jun 21, 2014, 11:50 AM
Burakko is offline
Burakko's Avatar
Joined Aug 2012
I bought the materials and have a question. If I build a 4 mm plywood will not be too heavy?
Old Jun 23, 2014, 12:26 PM
hogflyer is offline
Find More Posts by hogflyer
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
Have you downloaded Mark Porters plans? He calls out 6mm for some parts, .8mm for others. If you use 4mm then you will be heavy where the .8mm parts are, but can probably get away with replacing the 6mm with 4mm. You will probalby require larger motors for the craft to operate the way it should is you use all 4mm ply. Lightness is a key to hovercraft performance (both models and full scale), so, like an airplane, the lighter the better.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
4-Like New Masher 2000's on Hpi Star Rims StrangeGager Cars - Cars and Parts (FS/W) 6 Jan 21, 2005 06:06 AM
FS: Brand New Omei 2000 argarre Aircraft - Sailplanes (FS/W) 2 Jan 08, 2005 05:28 PM
FS: Brand New Omei 2000 argarre Aircraft - Electric - Airplanes (FS/W) 3 Jan 07, 2005 09:00 AM
New GEM 2000 Scale Lighting System A&J Aircraft - Electric - Airplanes (FS/W) 1 Aug 16, 2003 03:19 AM
FS: New 12cell 2000 NMH wamdue Aircraft - Electric - Airplanes (FS/W) 0 Oct 30, 2002 04:33 PM
