Old Aug 31, 2014, 08:23 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Question
Ailerons/elevons ?
OK, I got these plans for a He-1078B and while they're in Portuguese using a translator online I got it figured for sizes, material etc. The plans do not detail the ailerons, elevators or elevons. I'm thinking that they are shown at the ends of the wing, it's a flying wing but are they ailerons, elevators or elevons. Check out the pic below, the plans are very close to picture. The large control inboard is labeled FLAP on the plans. Thanks for any input in advance.
Dick
335driver is offline Find More Posts by 335driver
Old Aug 31, 2014, 08:52 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Pretty much beyond my knowlrdge, BUT give invertmast a PM, he did this
150% enlarged WingontheWeb HO-229
http://www.rcgroups.com/forums/showt...ght=Horten+229
He may be able to help you out!!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 31, 2014, 09:13 PM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
The outer portion is the rudder/yaw control. It is the section of the wing that is bent/canted downward.
The aileron is the one next to it. The inboard portion is most likely the elevator.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Aug 31, 2014, 11:37 PM
United States, FL, North Port
Joined Mar 2004
I agree with Kevin, the only thing in addition to that, is i would all of those surfaces into elevons (except the outer tip, which i would mix those surfaces into the elevator stick for extra pitch authority, but have the mix able to be turned off via a switch in case any undesireable tendencies emerge).
invertmast is online now Find More Posts by invertmast
Old Aug 31, 2014, 11:41 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
invertmast, thank you for the quick reply. I will certainly keep all these things in mind.
Richard
Old Sep 01, 2014, 02:34 AM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Looking forward to this one!Are retracts on the agenda?Nose wheel should be fun.
Stupot46 is offline Find More Posts by Stupot46
Old Sep 01, 2014, 05:07 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Stu.........probably not, if they are it ain't gonna be scale, not that die-hard...I'm thinking about a quick foam investigatory study first.
Old Sep 02, 2014, 06:29 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Keep in mind that due to the angle on the tips you will want to do a split control surface up and down at the same time to act as drag rudders. if not you will get a roll with yaw .
turbonut is online now Find More Posts by turbonut
Old Sep 02, 2014, 07:44 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
turbonut, don't really know what you mean "a split control surface up and down at the same time to act as drag rudders" Do you mean coupled with aileron movement? Like adding rudder while turning as in a Cub?
Old Sep 02, 2014, 09:20 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Each wing tip should have the control split from root to tip along the cord so it can deploy in both directions up and down.
Old Sep 04, 2014, 11:53 PM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
My BV-208 used elevons on the outer panels. I did not use flight controls on the main wing. There needs to be about - 4 degrees washout for the outer panels. I also added verticals for yaw stability.
http://www.luft46.com/bv/bvp208.html
I am building a He P.1079B/II which is similar to your plane. I will be using the outboard surfaces as elevons and inboard surfaces as spoiler/elevators. To make the yaw control simple I will be using the He P.1079B/I vertical tail.
I found that the elevon/ spoiler arrangement by flying my P-1111 . The inboard surfaces are better used as trimmer for pitch control and can be used as spoilers for landing (plane has ground effect).
Hope this helps
p901P901 is online now Find More Posts by p901P901
Old Sep 06, 2014, 12:21 AM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
I made a BV-P215 outta foam and used elevons on the inboard wing. I got a flight outta it but it was structural failure , I had no spars just a flat foam wing and it just fluttered and tore in half. But, it was in the air for a minute or so. This is something that I'd just like to do. Crazy I know but too many look-a-like foamies at the field.
Old Sep 09, 2014, 05:18 AM
Colchester UK
Joined May 2004
With my Arado 555 I have 2 elevons on each side on the outer drooped wing. The inner surfaces
are inner flap up outer flap down for landing to slow it down. The plane does have rudders.
http://jgwright.co.uk
The Horten has a similar arrangement with outer elevons and up flaps and down flaps for landing.
The Heinkel 1079 design has proved a problem when flown as a model and requires a vertical tail surface.
None of these early German designs had split yaw control like Turbonut suggests. They were found on the Northrop flying wings.
John
John Wright is offline Find More Posts by John Wright
Old Sep 12, 2014, 07:56 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Thank you John, I may have to rethink attempting this build. I like your Arado, good job
Discussion Programming elevons and ailerons-9C senormiller Radios 2 Jul 11, 2014 09:03 PM
Discussion Adding Ailerons to an Elevon'd F22 -need help with 9303 mix programming DesignGeek Radios 14 May 18, 2014 03:01 PM
Question FlyFly F4 - Elevons or Ailerons? jrf2 Foamy EDFs 2 Apr 11, 2014 07:37 PM
Discussion Elevons + ailerons Rampage Radios 9 Feb 08, 2014 03:57 PM
Discussion elevon mixing D6I aileron stick movement same as elevator. ell198679 Flying Wings 2 Nov 20, 2013 08:16 PM
