Old Jan 03, 2013, 07:55 PM
United States, OH, Grove City
Joined May 2012
Question
Can anyone id this old nitro?
Hello everyone I received this from my grandfather a few years back. Motor was locked up and had old servos and the fuel line in the tank was hard as a rock.
I rebuild the fuel tank assembly and got the motor free and running. Threw some new servos in there and she flys great..
The motor is an os .25
Does anyone know what model this is?
Thanks!
I would really like to convert this pane to bolt on wings any ideas?
paw10lo is offline Find More Posts by paw10lo
Old Jan 03, 2013, 08:37 PM
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Looks like a ugly stick. On this plane. Bolt on wings. I would install two wood dowels in the front of the wing and build a female end in the plane. You want these about 2" apart. Or as to where they fit inside the planes fuse. And on the back of the wing. Drill two holes for your nylon screws that will fit in your built up wood with metal blind nuts
Dale 813 is offline Find More Posts by Dale 813
Old Jan 03, 2013, 08:38 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
To convert to bolt on would need to split wing and make a new joiner with a tab to the front to lock into a new bulkhead at the front window. Then need to instal a mount at rear for blind nuts.
Dowls can also be used to slide into beefed up holes in the fuselage.
I can post some pics of one I did later.
1320fastback is offline Find More Posts by 1320fastback
Old Jan 03, 2013, 09:02 PM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
lol It's not an Ugly Stick, it's a Cosmo 25SR... I believe they kitted them back in the 70s and 80s. I have one above the garage that I scratch built 15 years ago and used to run an ASP 46 in. Very fun little plane to tool around in.
Here's a for sale thread on one:
http://www.rcgroups.com/forums/showthread.php?t=1432004
The wing doesn't have enough structure to bolt the wings on so you'd have to cut it open and put some blocks in there... it's a very standard build up however, it wouldn't be that hard to put a balsa block in the back and front to support a dowel up front and bolts in the back.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Jan 03, 2013, 09:06 PM
Joined May 2012
Wow really an ugly stick? The saddle seems shallow in the front for wood dowels? Could I build up the front with some bass wood Without compromising anything?
Old Jan 03, 2013, 09:09 PM
Joined May 2012
HA! Knew it had to be something different. It all makes since as to why it says cosmo on the wing. I figured it would need reinforcement in the wing
Old Jan 03, 2013, 09:16 PM
Joined Oct 2008
Yeah, my club had a competition and we built them as a group build project... had a bomb drop competition, high speed run and a couple other things to compete for. I put the biggest engine that complied with the rules and captured the speed title with an 87 mph (no dive) pass... one guy tried to make the plane as aerodynamic as possible and he was flabbergasted that all I did was put a big old engine up front and beat him by 10 MPH. It was a good time. I remember some people did build theirs to bolt the wings on and I don't remember if they used bolts in the front and a bolts in the back or if they used a dowel in the front and bolts in the back.
Old Jan 04, 2013, 02:17 AM
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
I still have a COSMO SR 25 kit.
The COSMO KING SR 40 was a great flying ship, if any one has a kit for one untouched, contact me.
fiery is offline Find More Posts by fiery
Old Jan 05, 2013, 06:12 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I bet that is one great flying bird! LOVE the airfoil....
tailskid2 is offline Find More Posts by tailskid2
Old Jan 05, 2013, 09:49 PM
Joined May 2012
One of my favorites.
Thanks!
Old Jan 06, 2013, 12:25 AM
United States, FL, Jacksonville
Joined Jan 2013
wow - a kit plane that your grandfather gave you ! treasure it! Fly it! - I'm sure thats what he wants you to do!
ninefingerstwo is offline Find More Posts by ninefingerstwo
Old Jan 06, 2013, 09:54 AM
Joined May 2012
Absolutely! I also have a nice stick that I got from him this past christmas. Still working on it though
Old Jan 09, 2013, 11:54 PM
Joined May 2012
Originally Posted by 1320fastback View Post
Had trouble finding this post again.
Anywho here are some pics of one I converted last year.
This is a Avistar which had a rubber band mounted wing.
I ended up using nylong bolts that
Very nice work!
Old Jan 10, 2013, 01:01 AM
USA, CA, Oceanside
Joined Jul 2008
Thanks, it flys beautifully now with big barn door ailerons.
Also with servo pockets now out on the wing I had a place to put weight for lateral balance.
It is worth it to do if you plan on keeping the plane.
Discussion Can anyone ID this Axi motor ? Axefly Electric Motor Design and Construction 16 Jun 19, 2012 09:39 AM
Discussion Can anyone ID the brand of this J3 Piper Cub? DYORD Fuel Plane Talk 8 Jun 10, 2012 11:39 AM
Discussion Can anyone ID what kit/frame this is (pic)? 22B Electric Heli Talk 5 May 17, 2012 09:27 AM
Help! can anyone id this hull wet banshee Racing Boats - Internal Combustion 4 May 02, 2012 08:32 PM
Help! Can anyone ID this HLG? rvillegachapa Hand Launch 14 Apr 20, 2012 11:44 AM
