Old Oct 25, 2014, 10:27 PM
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
D-3D Doesn't Disappoint...
... & she flies larger than her size would lead you to believe...
Originally Posted by Scottish_steve75 View Post
I am thinking about buying this plane as my next purchase, but need to be sure it ticks all my requirements first:
how well does it handle wind? and i mean strong gusts like 20mph not a light breeze
does it have any weak points that fail?
i can see from the videos it is clearly aerobatic, but with it being only about 1m in wingspan how does it fly?
Handles wind like a plane almost twice its size. Even so, 20 mph is a bit much for most any ship with a 40" WS...
Weak points (for me) were the tail feather linkages & connectors. I replaced mine with stouter Dubro ones & have been very satisfied with their performance. Still flying mine (mostly) stock but using a APC 13x6,5E prop & I did the battery shelf mod. Paint job leaves a lot to be desired but you get what you pay for...
The D-3D does really solid harriers with minimal wing rock. Probably due to the fact it has double wings, Does the nastiest tumbles too, to the point she seems like she'll tear herself to pieces but instead she just keeps on going & going...
She always puts a smile on my face & I wouldn't hesitate to replace her if I ever auger her in & end up turning her into packing peanuts. So far so good...
RCAV8T0R is online now Find More Posts by RCAV8T0R
Old Oct 26, 2014, 04:25 PM
If it flies, I probably have 1
United Kingdom, Fauldhouse
Joined Mar 2014
Thanks for the info, only slight deal breaker, 20mph wind is a gentle breeze here, lol
i have saw some larger and much more heavy versions of the pitts on hobbyking , they are both around 3.5Kg and i think 1 is 1.4m the other is 1.6m wingspan, perhaps those would be more suited to our gusty wind?
Scottish_steve75 is offline Find More Posts by Scottish_steve75
Old Nov 01, 2014, 09:51 PM
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
I too switched to the APC 13x6.5 with good results. I decided to try a Xoar 13x6 wood prop and now that is the only prop I run on all of the Dynam models. Be sure to balance the blades and the hub, it's well worth the time for the extra power.
MC
crawlspace is offline Find More Posts by crawlspace
Old Dec 11, 2014, 06:00 PM
My head in the clouds!
United States, CO, Colorado Springs
Joined Mar 2014
I just picked up a master airscrew 12x8 prop. Any thoughts on how the devil would handle this prop?
Cyclone Steve is offline Find More Posts by Cyclone Steve
Old Dec 19, 2014, 12:36 PM
RCAV8T0R's Avatar
Joined Apr 2011
Elevator Trim...
...has always been an issue with this bird...
I've know for a while that the incidence of the horiz stab to the main wing is off on this one. Been deciding whether or not to trim & shim the horizontal stab or just mess with the motor thrust line. Went ahead & shimmed the motor & added a bit of up thrust to see if I can dial down that elevator up trim somewhat. We'll see if this helps somewhat...
If not, I'll get out the scalpel & start slicin' & dicin' the tail feathers to get that stab to end up being parallel to the main wings & get this sorted out once & for all.........
Poll Dynam 3D/Aerobatic Planes - Which would you select? Diesel6401 3D Foamies 3 Jun 29, 2012 03:11 PM
Help! Blue Devil Destroyer Catevari Racing Boats - Electric 1 Jun 15, 2012 09:35 PM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 11:30 PM
Alert Last of the Devil's Brigade Twizter68 Life, The Universe, and Politics 2 Apr 13, 2012 12:33 PM
Devils advocate...Micro 3D Helis????? Flyin Brick Micro Helis 6 Nov 04, 2005 09:36 PM
