Old May 08, 2012, 12:24 AM
Joined Dec 2010
Jury rig a servo to test//need help ASAP
is there any way to test a servo without all the other gear?
Like straight to a battery just to check the throw, etc.
winggunner46 is offline Find More Posts by winggunner46
Old May 08, 2012, 12:42 AM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Short answer is yes, the question is whether or not it will do permanent damage. If that can not be answered then it would be best to just wait until you have the other gear, you could also take it to your local hobby shop, most likely they can and will hook it up to make sure it operates for you. I've not been in a hobby store yet that would charge for something like that either.
dedStik is offline Find More Posts by dedStik
Latest blog entry: More Confessions of a Smoker
Old May 08, 2012, 01:30 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
You cannot run a servo just by hooking it up to a battery. You need a PWM signal to control it.
A cheap servo tester will do the job. You can get them straight from China on eBay for like $3. It'll generate the PWM signal you need to run the servo... But coming from China, it might take more time than you have.
What are you trying to do? There might be another way of accomplishing it if you can tell us what the problem is.
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old May 08, 2012, 03:50 AM
Joined Dec 2010
Learner/nug
The one I am worried about controls the rudder and nose steering. by hand turning the arm it seems the servo will turn 180 degrees. Just basic lack of knowledge in the early morning hours.
Old May 08, 2012, 04:33 AM
Joined Feb 2012
Not sure how you think he can test a servo by connecting it to a battery exactly... You need at least a servo tester. I have this one, it is cheap, and works great: http://www.hobbyking.com/hobbyking/s...idProduct=8296
NFA Fabrication is offline Find More Posts by NFA Fabrication
Old May 08, 2012, 09:04 AM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
And DO NOT turn a servo by hand!!! You can easily strip out the gears inside it by doing so.
Glacier Girl is offline Find More Posts by Glacier Girl
Old May 08, 2012, 10:52 AM
dedStik's Avatar
Joined Feb 2012
Also mentioned taking it to his lhs for testing, 1 month delivery vs a car ride. And yes you can test a servo using batteries, I've always done it that way with analogs.
This is what I've used,
Old May 08, 2012, 11:19 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That is normal. All servos are able to turn much farther mechanically than the electrical input will command them. Even though the servo is capable of turning almost 180 degrees, the electrical control input will typically turn it only about 38 degrees in each direction.
And yes, it is not a good idea to turn a servo by hand. Doing so can easily strip the gears.
Larry
Lnagel is offline Find More Posts by Lnagel
Old May 08, 2012, 11:20 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That is one strange looking battery.
Larry
Old May 08, 2012, 11:36 AM
dedStik's Avatar
Joined Feb 2012
Not just a battery, but much much safer.
Old May 08, 2012, 06:11 PM
C₄H₁₀'s Avatar
Joined Aug 2009
Let's toss caution to the wind for a moment. Show us how you can test a servo by connecting it straight to a battery
Old May 09, 2012, 01:39 AM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
+1, I have one and it works great.
Dale Kramer, who designed the Lazair ultralight in the Smithsonian, agrees and uses it for the motor control of his Electric Lazair!
http://www.rcgroups.com/forums/showp...4&postcount=79
marhar is offline Find More Posts by marhar
Old May 09, 2012, 01:49 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Yes and the easiest way is to have a Servo Tester and a battery holder with 4 NiMH rechargeables in .... or an old LiPo you don't use for flying and an ESC / BEC ...
Servo Tester (Hobby Kings - I use this and it's very good) :
http://www.hobbyking.com/hobbyking/s...vo_Tester.html
and a simple battery holder + 4 supermarket NiMH batts in, from local shop with a lead from a dead servo.
The other possibility is where i bought an RTF model and later replaced the radio gear. That now sits on my bench as a testing set-up. Just because you don't want to fly with it doesn't mean it's no use ....
solentlife is online now Find More Posts by solentlife
Discussion Experiance sharing with Test Stand /Thrust Rig dk31 Power Systems 8 May 14, 2012 04:47 PM
Discussion Dangerous 9x issue need help asap Chewy2 Radios 18 May 09, 2012 02:51 AM
Discussion Newb needs help with kk 5.5 board asap please MOTOSTEIN Multirotor Talk 0 Feb 11, 2012 07:34 PM
Discussion Help Disposing crash lipo!! (Need help ASAP) Alex Schauer Batteries and Chargers 28 Feb 07, 2012 07:15 PM
Alert LIPO EMERGENCY need help ASAP ZSimon Batteries and Chargers 6 Dec 12, 2011 01:51 AM
