Old Nov 18, 2011, 04:07 PM
Joined Feb 2011
Help!
DynamGrand Cruiser questions
Hi guys. I was looking for a 2200maH 11.1v 20C battery for my Grand Cruiser, and I can't seem to find one anywhere. Are there any alternatives that I can use without ruining the plane?? Thanks!
runway34r
runway34r is offline Find More Posts by runway34r
Old Nov 18, 2011, 05:58 PM
Joined Feb 2011
Any help?
Old Nov 18, 2011, 06:16 PM
can't buy vaporware
7oneWo1f's Avatar
Joined Nov 2011
Would this fit?
Sky Lipo 2200 25c
Not sure if you're worried about the 25 C, but that shouldn't be a problem.
7oneWo1f is online now Find More Posts by 7oneWo1f
Old Nov 18, 2011, 06:37 PM
Joined Feb 2011
As long as it won't burn my motors out, I'm good! Thanks!
Old Nov 18, 2011, 10:21 PM
can't buy vaporware
7oneWo1f's Avatar
Joined Nov 2011
You're welcome. If a 2200 mah 3s is what you already have, switching from 20C to 25C won't burn your motor out (unless you were on the hairy edge of burning it out).
Usually, all other things being equal, a higher C will mean less internal battery resistance (technically, it is also possible for manufacturers to game C ratings by dissipating more heat without changing internal resistance, though).
This means in theory more energy delivered to the motor over the whole flight, and less power disappated as heat in the battery. Reduced internal battery resistence might also mean slightly more current at full throttle, all other things being equal, which shouldn't be a problem unless you were on the hairy edge of your ESC/motor limits.
Article Cox Sky Cruiser EP 2.4 GHz RTF with FlightFlex Construction Review 78dave Beginner Training Area (Aircraft-Electric) 91 Sep 28, 2014 11:36 PM
Question COX Sky Cruiser easy to fly ? not2worried Foamies (Kits) 4 Sep 26, 2011 08:15 AM
Discussion Cox Sky Cruiser with Cam dugmar Electric Plane Talk 0 Sep 24, 2011 04:34 PM
Discussion Sterling 32' Cruiser or the Berkley 22' Express Cruiser RussellTate Scale Boats 15 Oct 26, 2009 10:41 PM
