Old Mar 16, 2011, 05:55 PM
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
I got a chance to run Hugo's 5.8 GHz pinwheels through the our new Agilent 9912A FieldFox RF analyzer today and got the attached results for VSWR. Any comments?
Unfortunately we don't have the network analyzer or vector voltmeter "option" licenses yet, just the CAT (cable/antenna test) and SA (spectrum analyzer) .
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Mar 16, 2011, 06:46 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That's impressive for 5.8GHz. Looks like the elements were a bit short.
Mine aren't nearly as neat as his for sure. I also like to run a small section of coaxial cable to get the antenna away from the transmitter. The Fresnel zone is very small at 5.8GHz.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 16, 2011, 07:06 PM
Joined Mar 2010
Unfortunately the analyzer tops out at 6 GHz so I couldn't run it much wider, but it looks like 1.5 might be as good as it gets. I was lucky to track down an adapter kit that could handle RP-SMA to N-type today, let alone feed lines, but it is definitely very sensitive to objects (like fingers) in close proximity.
Here's the 5.4-6.0 GHz VSWR sweep.
Old Mar 16, 2011, 08:59 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Thx for sharing that with us.
1.5 is really not bad considering the frequency, a different after-shave and you might get different results
Did you test both?
Next ones will have a small coax (1/2 wave length)
Hugeone is online now Find More Posts by Hugeone
Old Mar 16, 2011, 09:19 PM
Joined Mar 2010
Hey Hugo, thanks for sharing the antennas with me, I just wish I had the license codes to enable the network analyzer so I could have plotted an impedance sweep on a Smith chart.
Post #226 had two attached images, one for each antenna's VSWR. The better of the two ranged from 1.5-1.8 and the other from 1.7-2.0
Next step is to get a regulator fro my RangeVideo tx and do some coastal ground testing. I might build a helical antenna for that work as I have some nice LOS shots ranging from 6-18 km.
Old Mar 17, 2011, 07:29 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Did you test both?
Or humidity will even change it. I bet a short run of coaxial cable will lower SWR due to the antenna being farther away from the test device. I make my 5.8 GHz antennas with about 1 wavelength or so coaxial and the antenna is formed into it. I also make it so the feed acts as a balun
-Alex
Old Mar 17, 2011, 03:58 PM
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Produced a couple of these great antennas at work today
Thanks again for your great instructions Alex!
David
Hogster is offline Find More Posts by Hogster
Old Mar 17, 2011, 10:11 PM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Those look fantastic.
Derek_S is offline Find More Posts by Derek_S
Latest blog entry: Iconic X
Old Mar 18, 2011, 03:27 PM
DODOLAND
Joined Feb 2009
Hi Alex,
Can you tell me if I can use RG58 50ohmn coax to connect antenna to the RX on 433mhz.Its a bit hard for me to find RG174 for the moment.I just want to make an extension.
Anthony.
flight01 is offline Find More Posts by flight01
Old Mar 18, 2011, 06:51 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes RG58 will work. In fact, I recommend it over Rg174.
-Alex
Old Mar 18, 2011, 08:26 PM
Build Fly Crash Repeat
crezzee's Avatar
Worcester UK
Joined Nov 2004
My skew planar wheel for my 2.4Ghz vrx.
I have used a length (1/2wave length)) of semirigid coax and 1.0mm mig wire.
crezzee is offline Find More Posts by crezzee
Old Mar 18, 2011, 08:40 PM
Joined Mar 2010
-Alex
The result with a random 50cm (~10 lambda) SMA feed line was a bit better.
Old Mar 19, 2011, 08:54 AM
Joined May 2010
Ask for inspection :)
Do you think this looks good?
aSa2 is offline Find More Posts by aSa2
Old Mar 19, 2011, 09:59 AM
Joined Mar 2010
doh.
Old Mar 19, 2011, 10:04 AM
Joined Mar 2010
I expect you'll have some non-ideal behaviour due to the proximity of the coax shield to the leg of the element that it is taped to. This could be modelled or measured but you need to have the tools and know how to use them...
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 49 Oct 15, 2014 10:23 AM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 07:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 10:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 05:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 06:00 PM
