Old Sep 24, 2008, 04:58 PM
somt1033 is offline
Find More Posts by somt1033
Hamburg, Germany
Joined Nov 2006
Aerodynamics of Flying Wings and Planform/Airfoil Issues
Hey Guys!
If if figured it out correctly the following is what i think to know:
Sweep is primarily applied to achieve Yaw stability and in combination with
washout it provides a positive zero lift pitching moment.
But you can also achieve a positive pitching moment by using reflexed airfoils.
Without any sweep. But to have better stabilty on pitch and yaw you use sweep anyways.
This leads me to the follwing question:
Reflexed Airfoils and washout serve the same purpose?!
If so, do you combine them or use just one of them???
Greetings,
Marvin
somt1033 is offline Find More Posts by somt1033
Old Sep 24, 2008, 05:53 PM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
Depends on the sections you are using. The more lift the root section produces, the more washout you will need at the tip as a general rule. The more 'lifty' foils tend to produce a stronger, negative pitching moment.
If you cut a wing without enough washout, you can overcome the negative pitching by reflexing the elevons, this does tend to produce more drag and affect handling though. Most commercial epp wings are cut without any washout, instead they rely on the tapered elevon being reflexed up a few degrees. The taper therefore providing more reflex at the tip- if you like, an artificial way of producing linear washout
miniphase is offline Find More Posts by miniphase
Old Sep 24, 2008, 05:55 PM
miniphase's Avatar
Joined Nov 2004
if you know the pitching moment, zero lift angle and camber of the sections (along with the dimesions of your wing) you can use the spread sheet from the Bsquared website to calculate the washout for you. I think there is also a German language programme on dasnurflugelteam website.
Old Sep 24, 2008, 06:07 PM
somt1033 is offline
Hamburg, Germany
Joined Nov 2006
I used a program for matlab called tornado.
Now i am using Nurflügel. It is better for the purpose of designig wings.
Right now i am tweaking wings it that program and try to understand what difference diffrent airfoils make.
Old Sep 24, 2008, 08:48 PM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Marvin -- Reflexed airfoils have a couple of disadvantages for models.
First, they are usually thin at the rear and difficult to build accurately and strong.
Also, the reflex produces a slowdown of the flow on the upper surface which has a negative influence on both lift and drag with low Reynolds Number flow.
HerkS is online now Find More Posts by HerkS
Old Sep 24, 2008, 11:34 PM
vespa is online now
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Actually, rearward sweep generally produces more roll stability than yaw but it is not really used in our models for either purpose. Sweep is typically used in a flying wing as a way of increasing the distance between the A.C. and the upward angled trailing edge (at the washed out wingtips). Plus you have a great place to mount fins, which maybe kinda work as winglets as well.
One of the core requirements for pitch stability is Cm0>0, which means that at a zero-lift angle of attack the aircraft must tend to produce a pitch-up moment measured from the aerodynamic center. For wings the A.C. is always at the 1/4 chord, for other planes it is in other places.
There are then basically 3 approaches to flying wing stability:
1. Use a conventional high-lift, Cm<0 (pitch down) airfoil, sweep it, then twist it a hell of a lot to create the pitch up force. A good example of this is the Boeing Scaneagle but this approach is seldom seen in models.
2. Use a fairly neutral airfoil with a little bit of sweep and twist (2deg) like most "Zagi" type wings. Great stability and ruggedness at the expense of drag and tip-stalls from the sweep.
3. Use a Cm>0 (reflexed) airfoil with no sweep. Very little pitch stability is possible with this approach and these designs are extremely sensitive to elevator trim/slop/damage but have the best performance.
vespa is online now Find More Posts by vespa
Old Sep 25, 2008, 01:53 AM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Originally Posted by somt1033
Hey Guys!
Sweep allows the tips to perform the same function as a conventional empennage. The sweep has the same influence as the tail moment arm of a conventional airplane i.e. The dynamic stability is proportional the square of the distance from the AC of the lifting surface to the AC of the stabilizing surface(represented by the blue lines in this drawing).
Yes, in pitch but not yaw. A reflexed airfoil can provide static stability but not dynamic. Sweep + twist provides both.
To some extent, yes.
That's a design decision. The designer's choices can get pretty complicated. That's what makes flying wings more interesting than “normal” airplanes
--Norm
nmasters is online now Find More Posts by nmasters
Last edited by nmasters; Sep 26, 2008 at 01:02 AM. Reason: added "in pitch but not yaw"
Old Sep 26, 2008, 04:46 PM
macboffin is offline
Find More Posts by macboffin
North London ENGLAND
Joined Dec 2006
Swept wings
There is another approach to "wings" which is slightly more efficient.
macboffin is offline Find More Posts by macboffin
Old Sep 26, 2008, 04:52 PM
Joined Dec 2006
"Straight" wings.
Sraight, reflexed wings work ok for full size also!
Old Sep 27, 2008, 12:51 AM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Neat! I hadn't seen that picture of the Facet Opel before. Most I have seen are unpainted
--Norm
Airfoil Database - Tailless and Flying Wings Buzz_Man Flying Wings 0 Jun 06, 2005 07:59 PM
Airfoil question for deltas/flying wings adamdb Modeling Science 6 Apr 06, 2005 12:00 PM
Zagi-type flying wings, what airfoil? Fredrik W Foamies (Kits) 5 Jun 24, 2003 03:53 PM
Flying wings, 1 or 2 vert. stab(s)??? g00bd0g Power Systems 7 Aug 04, 2001 09:03 PM
Break props on flying wings? Red Baron 47 Electric Plane Talk 4 Aug 03, 2001 11:49 AM
