Old Oct 02, 2002, 09:55 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
FMA Kokams are here!!
I ordered some Kokam lithium ion polymer batteries from FMA a month ago or so, but they quickly ran out. Well today I received a surprise package that contained my 4 1020 mah Kokam cells!! Woohoo! I immediately popped 2 on the scale and they are dead on 1.5 ounces as advertised. As you can see in the pic, they come as bare cells. They look strangely like foil covered chocolates I'm greatly looking forward to trying these out on ALL my QC powered planes, especially the M100 equipped planes. I'm also particularly curious to see what the 1/2 ounce weight savings over QCs does for the vertical on my Wing-E and Mini IFO!
For more info, jump to this thread:
Kokam Lithium Polymer Batteries!
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 02, 2002, 10:58 PM
fourleaf is offline
Find More Posts by fourleaf
Senior Member
Des Moines Municipal, Iowa, United States
Joined May 2002
Great news! I gotta get an order in.
fourleaf is offline Find More Posts by fourleaf
Old Oct 02, 2002, 11:32 PM
Jeff Costantino is offline
Find More Posts by Jeff Costantino
I am to the limit!
Jeff Costantino's Avatar
Coral Springs, FL
Joined Sep 2002
What is the maximum discharge? Still 2C like the Sony Energytec cells?
Jeff
Jeff Costantino is offline Find More Posts by Jeff Costantino
Old Oct 02, 2002, 11:34 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
I think you're gonna like these cells, Tres. You should lose 1/2 an ounce, and gain a few rpm. Now that FMA's prices are firmed up, and very reasonable, your beloved qualcomms may soon go the way of the Dodo.
Looking forward to your flight reports and comparisons. I never personally owned qc's, so my only lithium time is with polymers.
Marcus
MKH is offline Find More Posts by MKH
Old Oct 02, 2002, 11:56 PM
Forney, TX
Joined Mar 2002
Jeff-
==What is the maximum discharge? Still 2C like the Sony Energytec cells? ==
According to testing that you can read about in that other thread, the "safe" discharge is 4C, but people have been pushing 5C. This is also impacted by the size of the cells. Kokams are performing at a completely different level than any other li-ons out there.
Marcus-
I've hit the 3 amp limit on the QCs more times than I care to think about! I'm anxious to try the Kokams on some of those old tests. The weight savings and increased capacity over the QCs has me excited as well! I've got a pack charging right now, I think the Mini IFO will be the test subject
Old Oct 03, 2002, 12:01 AM
I am to the limit!
Coral Springs, FL
Joined Sep 2002
WOW!!! That's a pretty good discharge rate! 5C is plenty for most park flyers but you could always make a series-parallel pack for 7.2v and 10C amp draw..
Jeff
Old Oct 03, 2002, 12:12 AM
MKH is offline
MKH
MKH
Ohio
Joined Mar 2000
I can't back this up with any data, but I believe the 4C to 5C max discharge rates for these polymer cells is for short bursts only. I pull up to 4 amps on my 950's, but only for very short bursts, and I've had no degradation in these packs since new.
Marcus
Old Oct 03, 2002, 01:05 AM
fourleaf is offline
Senior Member
Joined May 2002
I have some 2 cell and 3 cell 950 Li-ions (not bad, but expensive) as well as Qualcomms (not bad and cheap! but a few shutdowns in my experiences as well). I just placed my order for some Kokam 560s, 1020s, and 3270s - cant wait to see how these Kokams perform, the weight sure looks good! I feel pretty confident that I have disassembled my last cell phone pack.
I am sure I will destroy or noticably degrade a pack or two during my brushless testing. I will let ya know how it works out.
Old Oct 03, 2002, 01:37 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I sure wish the 3270s would fit in a Switchback! A three cell pack of those, on a miniAC 1215/20 geared appropriately for about a 10X7 SF prop....... would be mah -ve -lous......
BEC is offline Find More Posts by BEC
Old Oct 03, 2002, 02:42 AM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Why wouldn't they? Just do a bit of re-engineering to put the cells in the wing instead of the fuse? Real planes store their fuel in the wings all the time, and what stopped people from doing it in the past was mostly the round nature of the cells...
Comatose is offline Find More Posts by Comatose
Old Oct 03, 2002, 07:35 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Hi,
I was just wondering - what do people use to charge the Kokam cells? Are you just using the Qualcomm charger? Would any mobile phone charger work OK?
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Oct 03, 2002, 09:53 AM
ls77 is offline
Find More Posts by ls77
Former bpp dude
Joined Oct 2001
Hello All, I am stocking the Kokam 1020's also & have many in stock. The 1020's are great for speed 280 & below applications requiring 4amps & below in current. You can push them harder into the 5+amp range but you MUST use throttle management. You can run them in parallel to double, triple, or quadruple their current capacity to handle motors from speed 300's- to hot speed 400 brushless setups. I have been running four 2 cell packs in parallel with a plane that will pull 26amps static. Very hard on the cells but its a blast to fly a plane with a 4,080mah battery pack that pulls that much current(no more 5 minute flights!). Please check out www.b-p-p.com for more info.
As for charging, the qualcomm charger will charge any of the cells from the 880's on up but the qualcomm charger usually stops at 8.2v so the charge on a two cell pack is a bit low. I have found a 5 dollar charger from RadioShack that will charge a 2 cell pack to its full capacity in aprrox 2 hours. I will post back with its catalog number if you guys would like to try to pick some up at your local RS.
I also will be stocking many different chargers as well as my own design within the next few weeks. For right now, the only way to charge 3 cell packs is via a $$$orbit or shulze, ginzel$$$$ chargers or through the Li-poly charger that wildrc & hobbylobby carry. Thanks
-Troy
Bishop Power Products
www.b-p-p.com (still under some construction)
ls77 is offline Find More Posts by ls77
Old Oct 03, 2002, 09:59 AM
uncled is offline
Find More Posts by uncled
Iron Mountain,MI
Joined May 2002
Link ???????
uncled is offline Find More Posts by uncled
Old Oct 03, 2002, 10:02 AM
uncled is offline
Iron Mountain,MI
Joined May 2002
http://www.b-p-p.com/products.htm I see - gotta change the link to include the dash.
Old Oct 03, 2002, 10:13 AM
ls77 is offline
Former bpp dude
Joined Oct 2001
sorry guys, I should allow at least 10 minutes after I wake up before I post
-Troy
Kokams are here. WJ Birmingham Batteries and Chargers 0 Oct 21, 2003 01:41 PM
G10 Frames for the Piccolo are here! Mario Electric Heli Talk 32 Aug 07, 2002 10:01 PM
My CP 8 x 1700's are here. (Yeah!!!) hmhoshi Electric Sailplanes 16 Oct 31, 2001 05:10 PM
Slim Gyms are here! (NSP) sal Parkflyers 13 Apr 26, 2001 05:55 PM
Sanyo CP-1300SCR are here! Ralph Weaver Electric Plane Talk 8 Apr 24, 2001 10:18 PM
