Old Aug 29, 2015, 06:43 PM
royalcasa is offline
Find More Posts by royalcasa
United States, FL, Lake Mary
Joined Sep 2014
Help!
Used CG boat with lots of deck lights
Hi all, I got this Essex island class CG cutter with lots of lights and resistors. I was told they are not the original lights all are upgrades. I have never done anything with lights, in fact this will be my first rebuild. I am hopping some of you can help me out with the lights and electrical. I don't even want to test anything till I know what I have. I will post some pics, if you need me to post more please let me know.
thanks guys
royalcasa is offline Find More Posts by royalcasa
Old Aug 29, 2015, 06:53 PM
Joined Sep 2014
more pics, she will also have an operating radar
Old Aug 29, 2015, 07:01 PM
Joined Sep 2014
more pics
Old Aug 29, 2015, 07:13 PM
Joined Sep 2014
and more pics of the radar
Old Aug 29, 2015, 07:19 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
It looks as though all the lights on the model are LEDís and as such will operate at 2 to 3 volts. The search light was originally a 3 volt bulb but it may have been changed to a LED also. I cannot see where the wiring terminates and what the power source was to power up the wiring for the LEDís. Since you are running LEDís for lighting you must make sure of your polarity on the wires. Ledís only run one way.
frankg is offline Find More Posts by frankg
Old Aug 29, 2015, 07:29 PM
Joined Sep 2014
sorry if my questions are ignorant, what and how should I power up the lights. should I use a separate battery source, and what about the radar. the previous owner run some lights below the water line, they will be coming of when I repaint the hull
like I said I have never done electrical,
Old Aug 29, 2015, 07:32 PM
Joined Sep 2014
well first thing I will read on, is how to hook up LED s
Old Aug 29, 2015, 07:34 PM
Joined Sep 2014
no power source came with the boat only motors and the esc.
Old Aug 29, 2015, 08:46 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Normal voltage to the LED's would be 3 VDC; since the builder installed resistors, you can use up to 12 VDC to power the light system. Usually the resistor is installed on the positive (long) lead to the LED.
CG Bob is offline Find More Posts by CG Bob
Old Aug 29, 2015, 09:15 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Can you verify the color bands on the blue resistors?
That may help decipher whether the model was 6 or 12 volts to the lighting.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Aug 30, 2015, 08:04 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Looks as though there are few versions of resistors aboard.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Aug 30, 2015, 10:19 AM
frankg is offline
Joined Dec 2004
[FONT="Arial"][SIZE="3"]When reading the resistance of the resistor banding throw out the GOLD OR silver end bands as they are percentage of tolerance of the resistor. To add you in reading the resistor ohms I have listed the chart for reading the value of the resistor.
http://nearbus.net/wiki/index.php?ti...olor_codes.jpg
Old Aug 30, 2015, 12:57 PM
Joined Sep 2014
Thanks for all your help guys
Old Aug 30, 2015, 01:01 PM
Joined Sep 2014
I will look at all the transistors and list the color of the bands, I will leave out Gold and Silver.
Old Aug 30, 2015, 01:03 PM
Joined Sep 2014
Thanks for the link to the band color chart
Sold FPV parts/electronics lot - antennas, motors, servo gimbal, etc. - lightly used RC2211 FPV Equipment (FS/W) 0 Jun 11, 2014 11:50 AM
Sold Fully Decked out DX7S With upgraded nibs and switch extentions and Back light mod Johnnymeg Aircraft - General - Radio Equipment (FS/W) 8 Dec 30, 2013 01:18 PM
For Sale Lots of multicopter stuff for sale! some new some lightly used!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 0 Nov 17, 2013 12:29 PM
Sold Pro Boat "Volare" hull with deck fittings fgn4048 Boats (FS/W) 2 Mar 22, 2012 07:24 AM
Help! Pro Boat lighting kit for CG Boat fgroza Scale Boats 0 Nov 10, 2008 08:12 AM
