Old May 02, 2014, 02:26 AM
SkySwiper is offline
Find More Posts by SkySwiper
United States, CA, Corona
Joined Jul 2011
Needle 100
Hello you guys trying to get a little input from you all. I have a Needle 100 not the DS version. What would you say the safe speed for DSing this plane?
Thank you
George
SkySwiper is offline Find More Posts by SkySwiper
Old May 02, 2014, 04:40 AM
airtimeasto is offline
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Australia, WA, Baldivis
Joined Aug 2008
On Mine the elevator popped in a violent shear at around 211mph but it has gone to 237mph In a smooth zone.
And that was the DSL version
airtimeasto is offline Find More Posts by airtimeasto
Old May 02, 2014, 07:37 PM
Terminator is online now
Find More Posts by Terminator
Yorba Linda, Ca.
Joined Oct 2003
Thank you
George
Ah,
Did I just read the words safe and Dssing in the same sentence?
Define Safe.
This from Thuro regarding the DSL, and the FDS….
and I quote:
The DSL is good for 400km/h 248.55 mph, with N100 FDS 7,5kg we flew 560 km/h 347mph 264.5 ounces if kg is kilograms… until the pilot crashed this bullet.
No idea where or whom flew it into the ground.
These are figures from Thuro when I inquired April 16, 2014.
No speed numbers were given on the CF Needle (your version)..fwiw is a very fun plane to fly I have put several flights on Arrens in big wind as well as light lift.
Fun predictable plane.
Bosleys site RCSPEEDS has 241 and a picture of a needle with ds on the wing which I believe to be the DSL version which would go with Thuros numbers….
So, safe speed dsing?
Well brother that is on you to figure out.
Alan
Terminator is online now Find More Posts by Terminator
Old May 02, 2014, 11:16 PM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
I think with a clean shear and well set-up linkages and servos, 200 would be about the limit
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old May 02, 2014, 11:48 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Sounds like if you modify the elevator to something a bit more up to it you could push it harder and find its real limit. From what I have seen of the DSLs they are up to flutter speed within a few laps on a strong day, and it seems its the elevator that usually flutters. Fix that up and who knows what you might do with it.
Cheers
josh18 is offline Find More Posts by josh18
Old May 03, 2014, 12:31 AM
Joined Jul 2011
Thanks you guys I really don't want to push it no use in blowing up a good plane when I can get a very good DS plane at the same cost. I guess keeping it under 200 would be a good idea. I am planing on buying a DS plane for next season. I think one of Spencers planes might be a good choice. On another note I sure wish I had listened to you all concerning the Blade XXL double carbon I bought. The plane blew up right away second or third lap at Norco I don't want to make that mistake again.
Thanks you all
George
PS safe
/sāf/
adjective
protected from or not exposed to danger or risk; not likely to be harmed or lost. LOL
Old May 03, 2014, 12:48 AM
Joined Jul 2005
I would personally keep the Needle 100 under 160 for longevity
Discussion Thuro Needle 100 - Build thread of sorts..... slopetrashuk Multi Task F3X 200 May 18, 2014 04:06 PM
Wanted Needle 100 Dbox Aircraft - Sailplanes (FS/W) 6 May 31, 2011 12:10 AM
Discussion Saito 100 HS needle valve question CRFan1 Engines 6 May 22, 2011 10:00 AM
Badger Air Brush Needle - 50-0402 Medium 150/100 YarSmythe Non R/C Items (FS/W) 1 Dec 09, 2009 11:06 PM
Discussion Low needle setting for Saito 100 jcflyrc Engines 7 Apr 01, 2007 11:54 PM
