Old Feb 13, 2016, 06:56 AM
DougV is offline
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
Very nice flying Air-Jon!!
-Doug
DougV is offline Find More Posts by DougV
Old Feb 13, 2016, 07:48 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Originally Posted by Heirmeistr View Post
In the video I don't see the smaller F-16 exhaust nozzle?
Probably before he installed it....
Originally Posted by JetMang View Post
Hey Guys,
Here's video of Air-Jon's Stinger90 from a couple weeks ago.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old Feb 14, 2016, 12:24 AM
Heirmeistr is offline
Find More Posts by Heirmeistr
If it flys, I like it
Heirmeistr's Avatar
USA, CA, Fullerton
Joined Jun 2007
You are probably right. I didn't catch the "from a couple weeks ago"
Heirmeistr is offline Find More Posts by Heirmeistr
Old Feb 14, 2016, 06:08 PM
Air-Jon is offline
Find More Posts by Air-Jon
world's slowest builder
Air-Jon's Avatar
CA
Joined Oct 2006
You guessed it, the video was from the 2nd flight. I put the nozzle on on flight 8. It definitely picked up some top speed with the nozzle. I was not having too much trouble fitting into the turbine pattern. I will try to get some radar speed runs next time I make it out to the field.
Air-Jon is offline Find More Posts by Air-Jon
Old Feb 15, 2016, 04:39 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Originally Posted by T3chDad View Post
Are the nose gear lights supposed to stay on all of the time?
I powered on the aircraft with the gear switch in the down position. Therefore the lights were on and the gear was retracted. Doh! I checked it on the bench today and it works as it should.
Old Feb 16, 2016, 08:37 AM
rlake is offline
Find More Posts by rlake
Joined May 2015
Stinger 90 main gear issue
Pilots,
Is there a drop-in trailing link strut available for the main gear on the stinger 90? I fly on a grass field that isn't the smoothest and I can see it being an issue on less than perfect landings. By the way I just flew recently after getting the flaps programmed and this thing lands unbelievably slooow!!! Lots of complements from other more experienced pilots.😄
rlake is offline Find More Posts by rlake
Old Feb 16, 2016, 09:12 AM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
Other grass flyers have reported success with the stock gear. The stock wheels are good sized and the oleos have some good suspension travel. I applied some synthetic lube to my oleos and worked them a bit and they really have some smooth action now.
for trailing links, your best bet would be the F-5/Scorpion/Mirage links as they are fairly straight when in the extended position. the T-45 links will require hogging out much foam, and will move the wheels back...making takeoff runs longer.
Old Feb 17, 2016, 07:00 PM
rlake is offline
Joined May 2015
Thank you Air-Jon!
Do you know what size the pins are on the stock retracts? The part I'm asking about has the flat surface that the grub screw fastens on.
Old Feb 17, 2016, 07:20 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
they are 4.1mm
http://www.motionrc.com/freewing-ele...shafts-type-a/
Motion is really good about giving us the details of all the parts. Spend some time looking at the spare parts from the different jets to see what may work for you.
Old Feb 17, 2016, 07:55 PM
rlake is offline
Joined May 2015
Wow! Silly me. I didn't bother to look cause I didn't think the specs would be listed. Thanks again.
Old Feb 18, 2016, 12:07 AM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
Wellllll.....to be brutally honest, about 90% of the time they aren't. Except for the time you really really REALLY NEED the info -- then it goes up to about 99.9%.
StarHopper44 is offline Find More Posts by StarHopper44
Old Feb 18, 2016, 12:35 PM
extra300 is offline
Find More Posts by extra300
United States, CA, Riverside
Joined Mar 2014
Can you please tell me where you get your 5800mah Glacier ? Thank you.
extra300 is offline Find More Posts by extra300
Old Feb 18, 2016, 12:55 PM
Air-Jon is offline
Air-Jon's Avatar
CA
Joined Oct 2006
Glacier = BuddRC.com
They sell a 6000 30c and a 5800 45c. I choose the 6000 30c as I am more interested in flight time than Max power. No shortage in power output for our 100A draw setups. That said, the Glacier 30c outperforms many 40-60c packs per the testing MCSGUY did. The 6000s are also 6mm narrower which allows them to fit in some of my smaller jets like the FW F-5 with room to spare.
Old Feb 18, 2016, 10:03 PM
Joined Jun 2011
Link doesn't work.
Old Feb 18, 2016, 10:35 PM
camoy is offline
Find More Posts by camoy
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Buddyrc.com
5800
http://www.buddyrc.com/glacier-45c-5...o-battery.html
6000
http://www.buddyrc.com/glacier-30c-6...o-battery.html
camoy is offline Find More Posts by camoy
Discussion Freewing F18 90mm versus Exceed F18 90mm Suprsonic Foamy EDFs 0 Aug 26, 2013 09:34 PM
For Sale LPU: NIB Freewing Blue Stinger Jet Syner01 Aircraft - Electric - Jets (FS/W) 1 Feb 12, 2013 10:56 PM
Sold NIB Freewing Stinger 64mm Sport Jet. (Red) thndr1mj Aircraft - Electric - Jets (FS/W) 1 Nov 10, 2012 03:27 PM
For Sale LPU: NIB Freewing Blue Stinger Jet Syner01 Aircraft - Electric - Airplanes (FS/W) 3 Aug 09, 2012 11:30 AM
Discussion F18 starmax 90mm - stingers replica fighter jet jayjet18 Foamy EDFs 7 Mar 08, 2010 02:33 PM
