Old Sep 03, 2013, 07:43 PM
BackyardBomber89 is offline
Find More Posts by BackyardBomber89
United States, IN, Vincennes
Joined Sep 2013
Help!
Power system for cart help!
I'm new here and I'm hoping I can get some help. I'm in an engineering club in college and our project for this year is to design a go cart of sorts that will do 60 mph or better. I was hoping to adapt some RC components on the market to create a power system to power my cart. Does anyone have any idea how much power it will take to do this? I was looking specifically at the larger turnigy out runners from Hobby King. Such as the 80, 100cc out runners. Any ideas or help out there?
BackyardBomber89 is offline Find More Posts by BackyardBomber89
Old Sep 03, 2013, 09:29 PM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
For 60 MPH you will need something larger then 100cc. Here are some larger motors:
http://www.electricscooterparts.com/
They have a page for school projects and with a 500 watt motor one team got 12 MPH. I own a cart with a 5HP Briggs and it will do maybe 15 MPH. I used to own 250 Motorcycle with maybe 20 HP and it had a top speed of about 70MPH.
http://www.electricscooterparts.com/...hourparts.html
I would estimate you will need 15,000 watts. I would look in the junk yards for motor from a Honda hybrid such as the Insight.
http://www.rcgroups.com/forums/showt...ighlight=honda
Here is a high performance motor that will do the job:
http://www.evparts.com/products/golf...ors/mt2112.htm
Here is another type of car that has a top speed of 125MPH. It uses a 20 HP motor but with a bit of over volting they get over 100 PH
http://www.plasmaboyracing.com/bluemeanie.php
mjsas is offline Find More Posts by mjsas
Old Sep 03, 2013, 11:48 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
My '65 Honda S90 (~8hp) would top 60mph, with no wind; I had to lie down on the tank, to minimize drag, but it would do it. So 100cc, or equivalent, could get him there, given time and a slick drag coefficient. Since 8hp is about 6kW, you may want to look for about 10kW.
Wintr is offline Find More Posts by Wintr
Old Sep 04, 2013, 10:42 AM
mjsas is offline
Joined Nov 2007
The Tesla electric car uses a three phase induction motor with a standard squirrel cage rotor. (Someplace on the web are photos of the motor's guts, I can't find it now.) Also it has no transmission, only one gear ratio. Three phase induction motors have full torque at stall and the torque curve is fairly flat so they have good performance. The motor control is simple as they do not need sensors, they run at one frequency. The speed is controlled by just the PWM.
Another factor with a three phase induction motor is that the torque is proportional to current squared so they can have full HP at very low speeds. With any PM motor the torque is only proportional to the current and may need a multiple speed transmission.
You might look into using a 5 HP three phase motor which should be only a few dollars at a scrap yard. It weights more but on a cart it should not be a problem.
Below is a graphic showing power loss in a Tesla car. This picture is from a Tesla web site. Air drag is the big factor at high speed.
Old Sep 06, 2013, 07:32 PM
Joined Sep 2013
Well. Thanks for the help and ideas. I ended up ordering two outrunners today. They are capable of 7000w each on 15s. They are rated up to 18s so hopefully that should be enough.
Discussion help with EDF power system for byron f-16 conversion raron455 Electric Ducted Fan Jet Talk 26 Oct 04, 2015 04:46 PM
Discussion Need help with power system for old Cap 232 ARF APD Power Systems 5 Aug 08, 2013 05:59 PM
Help! help with power system for 1/4 sig cub build neddy191 Power Systems 11 Apr 11, 2013 01:34 AM
Discussion Need help with Park 480 power system for Tyro 150 RC Floater Power Systems 4 Apr 06, 2013 06:37 PM
Help! I need help with choosing a power system for 4m Alpina sailplane flying jeep Power Systems 14 Feb 04, 2013 12:07 PM
